Engine transplant success . Thanks for the help.
Old 04 Mar 2011, 03:03 pm
Default Engine transplant success . Thanks for the help.
Have transplanted a low mileage 2002 engine into my 2003 PT. Had to splice in the ECM loom for the engine and obtain the SKIM and key from the donor. Fired up perfectly first time. Only had a slight heat high temp issue, but discovered that the Rad fan is faulty (probably why the original motor cooked). Just got to re-insulate the loom and off we go -time for the custom paint job. Wey hey!!!
Thanks for UptownSport and KREWZIN the links for the manuals and advice.
Wolfie
Old 04 Mar 2011, 05:11 pm
Default Re: Engine transplant success . Thanks for the help.
What did you do about EGR? 2002 had it, 2003 didn't.
Old 04 Mar 2011, 06:54 pm
UptownSport's Avatar
The heads are the same. Drill or use the EGR block as needed.
(Cheap plug, I have this for sale!
2.4 Cylinder Head '03 Sebring PT SRT4 SRT-4 '02-10 Neon - eBay (item 280637067963 end time Mar-06-11 19:48:54 PST)
Big question: Did you get a NGC to work in a NON NGC vehicle??????????????
P0304 Success elmeyer Tech & Performance Forum 5 21 Jun 2010 09:24 pm
Engine Transplant BT7 General Turbo Discussions 5 14 Sep 2009 09:13 pm
Zoo Cruise a Success PToholics Anonymous Southeast PT Forum 0 24 May 2004 09:01 am
First meeting a success turbomangt General PT Cruiser Discussions 3 14 Sep 2003 02:19 am
