is it a balljoint problem or a wheel bearing problem?
Old 05 Mar 2011, 04:14 pm
Thumbs down is it a balljoint problem or a wheel bearing problem?
i have a kinda rubbing noise from the front passinger side that stops when i turn the wheel to the left i am torn on if i need to replace the balljoint of the wheel bearing someone please help me
Old 05 Mar 2011, 04:24 pm
UptownSport's Avatar
Default Re: is it a balljoint problem or a wheel bearing problem?
Not going to say it isn't the wheelbearing, Jack it up and see if there's play in
the ball joint. Chrysler says to just crawl under it, grasp the grease zerk,
see if there's play ...
Lots of things can cause noise, it's best to inspect it.
Old 05 Mar 2011, 04:33 pm
ya cause last time i had issues i played the try iut and see game and i spent over $400 on a $200 problem
Does This Sound Like Wheel Bearing Problem?? NewPTCruiserInPA Wheels, Tires, Suspension 7 07 Apr 2010 07:26 am
HELP: Turbo Bearing Problem LaP Turbo Performance 2 09 Nov 2009 08:16 am
axle nut torque/ wheel bearing problem 2tonSS General Turbo Discussions 3 28 Aug 2007 07:38 pm
Problem with a wheel bolt Striker Wheels, Tires, Suspension 13 17 Aug 2006 05:27 pm
Wheel clearance problem ? pt4u2nv Wheels, Tires, Suspension 1 15 Jan 2004 11:55 pm
