Boiling and Bubbling OVERHEATING Still.
Old 05 Mar 2011, 04:44 pm
icharlie's Avatar
Exclamation Boiling and Bubbling OVERHEATING Still.
After checking everything I know in my limited knowledge, My 02 PT is still overheating. 144,000 miles. I have replaced: Radiator, Water pump (and timing belt), fan, thermostat, radiator cap and checked to ensure the fan is kicking on. I am inclined to think itís the head. Any thoughts, tips, or tricks? Thanks
Old 05 Mar 2011, 05:51 pm
cruserdad1976's Avatar
Default Re: Boiling and Bubbling OVERHEATING Still.
Im only asking but you did bleed the system
Old 05 Mar 2011, 07:00 pm
Gotta agree with cruserdad. If air gets in the system the boiling point of the coolant drops way down. It's supposed to be a closed system with no air which alows coolant to go back and forth between the radiator and the overflow tank. Air in the system stops that transfer.
Old 05 Mar 2011, 07:11 pm
UptownSport's Avatar
I have a head for sale!
But they are very good pieces, rare to see problems.
Would you mean headgasket?
Much more likely.
There is a bleeder on the water outlet neck.
Old 05 Mar 2011, 08:47 pm
WolfmanG's Avatar
welcome to the site, greetings from San Antonio from Eve and I.
Sorry to hear about your prob. Are you using HOAT coolant? Is there white smoke coming out of your tail pipe?
-Danny Wolfman G
Old 06 Mar 2011, 05:10 am
swanjack's Avatar
This happened to me, it was the head gasket, exhaust gases were getting into the coolant. I tried everthing before admitting the gasket had gone.
IMO an air lock would not cause the bubbling, as you need gas getting into the coolant constantly to produce the repeated and often violent surge of bubbles that purges through the system. I also read somewhere that the system is self bleeding as long as you follow the coolant replacement method properly i.e. any little air that remains will make its own way out during the first few heating/cooling cycles.
Old 06 Mar 2011, 07:45 am
When manufacturers came out with ball joints and knuckles that didn't need lubrication they did away with the grease fittings. If the PT was self bleeding, why did they add a bleed screw? ...and it does work!
Old 06 Mar 2011, 12:30 pm
QFT
That bleeder facilitates refill, just voids under thermostat, not the head per se.
Thermostat has either a hole, or a 'jiggler' to bleed vapor / air.
He'd have to leave it open during operation which would void the coolant
also, but the thermostat is already open
There's a headgasket How-to with pics I'm working on- get the FSM from
someone, it's not impossible
Old 06 Mar 2011, 05:23 pm
well then try this drive it to make sure it still is bubbling and over heating then bleed it that is a simple 5 minute job and see what works you really have nothing to loose
Tags
cap, overheating, radiator, thermostat, water pump
2004 PT Boiling Over Help 2004 Tech & Performance Forum 10 18 Dec 2010 01:43 am
Car is off, Boiling Coolant ptcruzrmama General PT Cruiser Discussions 17 15 Aug 2010 12:21 pm
Boiling over - not overheating ionheavens General PT Cruiser Discussions 12 19 Jan 2010 12:01 pm
Help!!!!! Car has bubbling noise JazzeCouture General PT Cruiser Discussions 3 13 Oct 2008 08:53 am
Bubbling noise jgclark Tech & Performance Forum 5 09 Jan 2008 01:14 pm
