Error code P0300 & P0304
Old 07 Mar 2011, 05:18 pm
Question Error code P0300 & P0304
I have an '07 PT turbo with about 106,000 miles and it's starting to run poorly. I checked the codes and found P0300 and P0304. Both indicate miss cylinder firings. I have replaced the plugs and the wires but it's still there. What might be the next logical step? I'm thinking the PCM.
Old 07 Mar 2011, 05:28 pm
Default Re: Error code P0300 & P0304
i presume you did the timing belt/water pump change due at around 100,000 mi.
Error Code P0304 Cylinder 4 Misfire Detected WV05Cruiser Tech & Performance Forum 16 23 Feb 2016 10:33 am
code p0300 means ?? bobs turbo pt Tech & Performance Forum 16 27 Feb 2015 09:49 pm
error code ques-... got a p0300- random misfire... batta Tech & Performance Forum 4 18 Apr 2010 03:26 pm
Error Code P0304 Max Tech & Performance Forum 2 30 Mar 2009 03:46 pm
Code P0300 rszappa1 Tech & Performance Forum 2 30 Nov 2005 12:47 pm
