P0522-0523
Old 08 Mar 2011, 07:06 pm
Default P0522-0523
Ok car started to stall on the thruway today, I recently had the camshaft sensro fixed 6 months ago. Also had oil pressure switch and oil pan gasket fixed in the last 1 1/2yrs. The mechanic said that the code indicated low oil but the oil levels were fine. So he said he reset the computer and the OBD light is not on and it is running fine. I'm wondering if I should have him take a look at the oil pressure switch just to make sure.
2005 Pt Cruiser Convertible Touring Edition
Jvc KD-R300 Dash Unit
Kicker K35 3.5in Dash Speakers
Pioneer TS-A1673R 6.5in Door
Pioneer TS-A6963R 6x9 Rears
Infinity Kappa 12in Sub
Infinity REF5350A 5 Channel Amp
Old 08 Mar 2011, 08:22 pm
Default Re: P0522-0523
Don't know if you can take a look at the switch and see if anything is wrong. There has been quite a few owners with problems and it turned out to be the switch. Always use MOPAR/Chrysler parts and the oil pressure switch isn't expensive. Should be a snap for the mechanic to change it out.
Old 08 Mar 2011, 08:27 pm
Oil pressure switch is a problem area. I have the same problem. It comes on occasionally when I start the car. If I shut it off and restart it's fine.
I figure that running 0w30 synthetic for the oil might have something to do with it so I don't worry about it. When it's warm I might try another sensor.
Right now I'm fighting with a bad radiator fan code. That will be a pain. Wish me luck!
Old 09 Mar 2011, 06:57 pm
Apparently the oil code was an old stored code , so I got the oil changed and when they started the car the code for the camshaft sensor came on. Since it was replaced in sept they put it a new one free of charge. So we shall see if anything new happens.
Old 09 Mar 2011, 07:14 pm
If your not going to the dealer, chances are the mechanic is using after-market sensors and that's why it isn't lasting very long. Our PT's don't like store bought sensors and only Chrysler/MOPAR electrical parts are the only things you should use.
Multiple Codes (P0340/P0522) higear4 General Turbo Discussions 19 05 Sep 2011 05:30 pm
P0522? Docsdx General PT Cruiser Discussions 13 12 Feb 2011 12:27 am
'04 limited turbo throws code p0522 and p0508 Blugirl Tech & Performance Forum 5 06 Dec 2010 04:24 am
