Hyper Fan
Old 09 Mar 2011, 12:10 am
Default Hyper Fan
Greetings to everyone. New member here, but have been a long time looker. I regret that my first post is an issue, but I need some help.
Yesterday I noticed my PT's radiator fan was constantly kicking on and off when in defrost mode. I know the compressor runs on defrost, but in my case the fan goes on for about 30 seconds to 1 minute then turns off and before it finished spinning down it kicks back on again. I have never noticed this behavior before in the past 9 years of ownership. I live in a remote area and it takes me about 100 miles to get to a trusted mechanic, so I would need some info or a link to another posting with the same problem before traveling.
Other info: My PT is a 2002 Classic with 63,xxx miles with regular maintenance. I had the A/C system inspected and recharged last summer, so I'm confused as what could be going on.
Thanks in advance for the help.
Old 09 Mar 2011, 06:00 am
Default Re: Hyper Fan
Welcome to the forum.
Your right about the fan kicking on with the compressor, it's supposed to do that in A/C mode or defrost. What you have going on (I believe) is that you are little low on R-134. I know you just had it recharged last summer but I think if you have it inspected again now it will show that it's low. One of the symptoms of a low charge is the compressor kicking on and off more rapidly than normal and the fan is following this on/off mode.
Sure sounds like the A/C is cycling and causing the engine fan to cycle with it - is engine temp okay?
Old 09 Mar 2011, 07:44 pm
Thanks for the quick replies. I actually turned on the A/C on the way home today and while the fan stayed on steady, the compressor was kicking on and off kind of quick. When I turned the knob to defrost both the fan and compressor were going on and off at the same quick frequency. As for the engene temp. it stays in the middle and reads out between 198 and 209 degrees.
Now I know where to start and I would not doubt if it is low on R-134a since the old local 'stealership' worked on it 2 years ago.
hyper grounding yteka99 Sound and Security Forum 18 22 Jun 2009 02:35 pm
N/A Hyper ground KingKole02 Tech & Performance Forum 12 20 Jul 2005 08:23 am
got my Energy Suspension Hyper flex kit Ctown Wheels, Tires, Suspension 10 31 Dec 2004 02:00 pm
Hyper Grounding Mean Green Turbo Performance 25 19 Nov 2004 02:57 pm
