Engine Code P0456?
Old 10 Mar 2011, 02:14 pm
Default Engine Code P0456?
Vehicle: 2006 PT Cruiser, base model
My check engine light came on last night; I followed the sticky here on how to retrieve codes and it gave me P0456, however it was not in the list of error codes on the forum. What does that code mean?
so i googled it and found another post here that says its the EVAP SYSTEM SMALL LEAK -- so what does that mean and how can I get it fixed? and do I need to take it to a Chrysler dealer or just any mechanic? and anyone know how much it costs?
Old 10 Mar 2011, 03:03 pm
Default Re: Engine Code P0456?
There's a good chance that the last time you bought gas, you didn't click the gas cap on tight enough (at least 3 clicks). You can tighten it now and wait to see if the fault light goes out or tighten it and take the negative battery cable off for about 5 minutes. That will get rid of the light and reset the computer. If the light comes back on again, it could be a bad gas cap or a small leak (vacuum line someplace but try the easy way first.
Tags
code, cruiser, engine, error, p0456
Error code P0456 & 0340 RoadTramp113 Tech & Performance Forum 12 21 Feb 2011 08:29 pm
2002 Pt error code P0456 chellee Tech & Performance Forum 2 24 Jul 2008 07:56 am
How Serious: 0441 Engine Code?? BB General Turbo Discussions 5 29 May 2007 08:51 pm
0441 Engine Code BB General Turbo Discussions 0 21 May 2007 06:16 pm
code p0456 Punch General PT Cruiser Discussions 0 26 Aug 2003 02:10 pm
