Alternator Voltage PT 2006
Old 10 Mar 2011, 05:40 pm
Default Alternator Voltage PT 2006
Anyone know what the alternator voltage output is is for a 2006 pt?
When the car is running what is a normal voltage range when I check it at the battery terminals?
Thanks for any help.
Old 10 Mar 2011, 05:51 pm
Default Re: Alternator Voltage PT 2006
as far as i can remember, most, if not all, are kicking out something like 13.8.
i could be wrong, tho.
Old 10 Mar 2011, 05:57 pm
other sites say between 13.5 and 16 is acceptable. they say an average is 14.2.
Old 10 Mar 2011, 07:07 pm
Thanks for the replies, much appreciated.
Old 11 Mar 2011, 09:53 pm
I'm running mine at 14.6, really brightens up the headlights, keeps the stereo crisp and clear.
Old 11 Mar 2011, 10:08 pm
/threadjack
Chromenut,
Are you using an external regulator? If so, do you have one that you recommend? I've been considering doing this for some time since I run a ton of electronics.
Thanks!
/endthreadjack - my apologies
Old 11 Mar 2011, 10:10 pm
Originally Posted by paulrosenthal View Post
/threadjack
Chromenut,
Thanks!
Nope, easily adjusted with the DSP!!!
Old 11 Mar 2011, 10:28 pm
Wish it was that easy for me, I have an 01 NA, so I may check into an external regulator.
Thanks Chromenut!
alternator output voltage SilverCruiser Tech & Performance Forum 12 15 Jan 2017 07:47 pm
Voltage Spikes- Help! UptownSport Tech & Performance Forum 1 29 Jan 2011 12:31 pm
Where to find a hi output alternator for a 2006 non-turbo?? Samson Tech & Performance Forum 0 27 Dec 2009 12:10 am
Voltage Stabilizer djpadko Tech & Performance Forum 6 13 Aug 2008 03:24 am
Low Voltage? GTPT Turbo Performance 5 21 May 2003 01:48 pm
