performance air filter ... engine managment light now on ??
Old 12 Mar 2011, 05:26 pm
reaper's Avatar
Default performance air filter ... engine managment light now on ??
hi all
fairly new pt owner here
today i fitted an aftermarket air filter after fitting it the engine managment light has come on
any ideas ?
Old 12 Mar 2011, 07:48 pm
Default Re: performance air filter ... engine managment light now on ??
If the car is still running fine and you don"t have a OBD reader, I would disconnect the negative battery terminal for about 15 mins. Then replace.
If it returns you will have to get the code read to find out what the problem is...
Hope this helps
Old 13 Mar 2011, 10:54 am
reaper's Avatar
car was still running fine (better pick up with new air filter ) i did as you said and it worked a treat cheerz fella
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
DROP IN PERFORMANCE FILTER vs. AIRADE GT TURBO?? mjb457 Turbo Performance 5 21 Jul 2010 09:34 am
Car Sometimes won't start (oil pressure light & Engine Light) gerardio Tech & Performance Forum 6 18 Jul 2008 08:22 am
How about some engine and performance ? yellowpanel Turbo Performance 2 09 Oct 2004 08:34 pm
engine performance? PT Chix Tech & Performance Forum 14 25 Jul 2003 12:16 am
