Timing off one tooth
Old 14 Mar 2011, 11:29 pm
Default Timing off one tooth
well, I got it all put back together after head gasket,timing belt,water pump,replacement,and of course it starts and runs rough, pretty sure I'm off a tooth, wondering how much less I have to remove to just rotate the belt??? Thanks
Old 15 Mar 2011, 12:35 am
tryingbe's Avatar
Default Re: Timing off one tooth
No short cut there. The only way to access the tensioner is to remove that 3 bolt mount bracket that the engine mount is bolted to. Everything will have to come off again, except the tensioner.
Check it again before you decide to pull everything off.
85 GLH
Watch out for anchor engine mounts!!
Timing Belt DONE!!!! wheelgarage Tech & Performance Forum 6 19 Oct 2010 10:38 am
Timing Belt quicksilverdon Tech & Performance Forum 12 18 Aug 2010 01:24 pm
Timing morrisbeer General PT Cruiser Discussions 1 06 Apr 2009 07:28 pm
Timing DreamCurZ03 Tech & Performance Forum 3 25 Nov 2008 02:41 pm
