ground wires
Old 16 Mar 2011, 12:18 am
Default ground wires
when replacing my brakes on my 06 cruiser . I noticed a green wire that was grounded to the wheel post..Does anyone know what they go to because both were cut in half?
Old 16 Mar 2011, 05:42 am
Default Re: ground wires
It's part of the grounding system for the PT. Without those wires, static electricity builds up and goes to the wheel bearings and can cause pre-mature failure of the bearings. Replace or repair both of those ground straps/wires.
Old 16 Mar 2011, 10:02 am
It's also tied to the ground loop for the ABS system. Really should be connected.
Old 16 Mar 2011, 10:33 am
UptownSport's Avatar
It's an anti-static line- Design, as the one on hood, is to prevent radio interference per FSM
Old 16 Mar 2011, 03:30 pm
Everybody has their own opinion. Here's the thread where I found a quote from one of Chrysler's engineer's:
ground wires from body to front struts?
ground wires from body to front struts? jacarc1 General Turbo Discussions 16 09 Aug 2014 12:34 am
where to ground amp bhunt41 Sound and Security Forum 5 29 Aug 2011 03:14 pm
Ground Wires? psychejim6077 Tech & Performance Forum 10 10 Jan 2011 10:04 am
where to ground my amp CruiserDan Sound and Security Forum 6 17 Dec 2004 03:43 pm
OEM Ground Effects 1lowufo Exterior Accessories Forum 3 24 Apr 2004 07:48 pm
