Occasionally the belt driving my accessories will squeal. It doesn't happen very often, usually when it's cold or it's wet outside. Because of this squeal I wonder if my P/S pump, A/C pump or alternator might be starting to bind up or fail.
This is a serpentine belt with a tensioner, right? This shouldn't squeal unless it's wet or something is jamming up. Maybe it's just old. My questions are this... - Is it difficult to swap? - Can I run the car without it? How about for a short test? - What are the chances that I need to replace the tensioner? This is on an automatic 2007 base PT with about 45000kms on it. Thanks for the help folks! Most of my posts are done while I'm at work, so looking things up and checking the car can be difficult. |
on my 2001 the alternator has it's own belt. the serpentine belt drives the p/s and a/c. replacing them is a bit of a chore due to the lack of space to work with.
i would try a belt dressing first to see if that clears up the squealing. oh, and pick up a haynes manual. lots of illustrations to help you out. about $20 usd. and yes, the serpentine has an automatic tensioner. Last edited by soyomb; 17 Mar 2011 at 12:50 am. |
It's usually the alternator belt that starts squeaking/squealing because it has no automatic tensioner. Like all belts on ALL cars, it will eventually stretch and since it has no automatic tensioner, you'll have to tighten it up manually like in the old days.
The other belt (power steering and a/c ) can give you a squeal even if the tensioner and belt are still good if you have spilled antifreeze on it as you are topping off your coolant level by opening the system at the t-stat fill point. It's directlly above the belt and is the main reason for the bleed valve on the t-stat housing. It prevents the bubbling out of the air/ coolant mixture that would invariably drop down onto the belt. unfortunantly, once you get antifreeze on this belt you can pretty well guarantee you'll need a new belt to get rid of the squeal. It immediately soaks into the belt and creates a slick spot that will produce the squeal until you change the belt. ![]() Jerry Last edited by wwpptc; 19 Mar 2011 at 09:41 pm. |
mityqwik,
Who did the timing belt in the first place ...dealer or private mechanic?
Rules of the forum have been updated as of *07/07/2019* Please read them over. - All decisions by the Moderator are semi-permanent, can and may be changed at his discretion but definitely will be the final word. Any action performed by the Administrator or Moderators are not to be discussed on the forum. |
If your happy, that's all that counts.
Tags |
accessory belt, belt, squeal |
Thread Tools | |
Display Modes | |
accessory power lead | urimashe | Sound and Security Forum | 17 | 21 Dec 2010 11:18 am |
120 volt accessory ports | jeffroandy | General PT Cruiser Discussions | 15 | 20 Jan 2010 09:20 pm |
Timing belt changeout questions!!! | 2002ptcruiserwoody723 | Tech & Performance Forum | 7 | 12 Nov 2009 07:32 pm |
2008 accessory options | era | Exterior Accessories Forum | 11 | 14 Apr 2009 12:34 pm |
Timing Belt questions | dehcho | Tech & Performance Forum | 7 | 02 Dec 2008 12:22 am |
