Changing Auto Trans Fluid
Old 18 Mar 2011, 07:17 pm
mjb457's Avatar
Default Changing Auto Trans Fluid
I know its been posted;;help with where or hints... can the trans fluid be easily changed with a set of ramps & basic tools & a big pan? I know it takes ATF4.. i would get a Mopar trans kit,,any other tips & obviously much cheaper than dealer but anything I need to know? Thanks MJB
Old 18 Mar 2011, 08:23 pm
Default Re: Changing Auto Trans Fluid
What you need to know is by doing it yourself, your changing about 4 quarts out of the 16 quarts that the system holds. But that's up to you.
Old 18 Mar 2011, 09:15 pm
cruserdad1976's Avatar
crezwin it is more like 6 quarts and the filter and mine holds 12( that is what they told me at NAPA im sure they could be wrong)) so its right at half
Old 18 Mar 2011, 10:03 pm
UptownSport's Avatar
They used to have plugs in the Torque Converter.
Don't see why you couldn't drill and tap 1/16" pipe hole, drain
heat exchanger
Old 19 Mar 2011, 02:01 pm
mjb457's Avatar
guys thanks--getting it done at the dealer-- as per crewzin
Old 19 Mar 2011, 02:48 pm
I hate it! Crewzin is right again.
Crewzin, you know I'm just kidding.
Jerry
Fluid for auto trans oil cooler nighthawk417 General PT Cruiser Discussions 2 01 Jan 2011 08:45 pm
synthetic trans fluid ok? 85_305 Tech & Performance Forum 11 24 Jul 2009 11:41 am
trans mission fluid|? whipplep General PT Cruiser Discussions 7 30 Sep 2008 06:14 pm
TRANS FLUID DARK270 General Turbo Discussions 10 31 Jan 2005 05:29 pm
ATF+4 auto trans fluid finally available MX-5 Tech & Performance Forum 3 04 Sep 2003 01:20 am
