timing belt?
Old 20 Mar 2011, 05:21 pm
Default timing belt?
hi i am going to order a timing belt kit from rock auto as suggested in the forum but is one kit better than the other (gates /dayco) i think i should get the one with the belt, tensioner, idler and water pump. should i get the seals also. i would like to have everything on hand before i do the job. thank you jim hoysa 2005 pt
Old 20 Mar 2011, 05:31 pm
Default Re: timing belt?
Jim,
What seals are you talking about? I had a small leak on the crankshaft end and it took a new seal but that wasn't discovered until the mechanic took everything off. The kit should come with any gasket that are needed (water pump).
Timing Belt ? veracruise Tech & Performance Forum 23 09 Sep 2010 10:43 am
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
timing belt greg55 Tech & Performance Forum 1 08 Mar 2010 09:19 pm
timing belt help bowtie_65 Tech & Performance Forum 2 29 Nov 2008 02:12 am
