Elec window fuses
Old 21 Mar 2011, 06:12 am
Angry Elec window fuses
Can anyone tell me where the fuse is located on a '55 PT classic.
The manual is useless, and now my n/s/f window won't close.
Any help will be gratefully recieved.
Old 21 Mar 2011, 08:27 am
Default Re: Elec window fuses
Welcome to the Forum!!! 55 PT?? no such a thing.
Old 21 Mar 2011, 10:33 am
The query is for a 2005 on a 55 reg PT Cruiser, I hope it helps, so that someone can help me out.
Old 21 Mar 2011, 11:06 am
Kawizx9r's Avatar
Even though you're outside the US, I would suspect that the fuses would be located on the driver's side the way ours are.
There's a small removable panel just 2 feet below the side-view mirror adjustment. Pop the panel off (excessive force not required) and you will see a host of fuses. Behind the panel you removed should be a diagram of your fuses, as well as what size fuse and what they are connected to. Looking at the fuse panel itself, you'll see a plastic trim that goes around the fuses as well as numbers for each fuse. Carefully remove it (it's brittle) and you should be able to remove/replace whatever fuse you need to replace.
Kawi is a friggin genius!
Old 21 Mar 2011, 05:41 pm
As was just said. Like ours, the C/S 20A Pwr Window fuse is located in the fuse panal by the driver left knee. The two top fuses are located horizontally above all the rest of the fuses. Left one for Power Windows, right one for the Headlamp Switch.
WTB 01-05 passenger aigbag cover, Elec. Blue freezingbelow Classifieds: Want To Buy 0 15 Mar 2010 01:59 pm
Elec Problem??? Shiniquiet Tech & Performance Forum 1 24 Aug 2009 11:35 am
fuses jozbez General PT Cruiser Discussions 2 14 Jan 2009 04:12 pm
Where to tap for power for elec. boost gauge? NorthernPT General Turbo Discussions 3 18 May 2005 10:32 pm
Warranty/Elec. Bigin General PT Cruiser Discussions 4 04 May 2004 09:28 am
