2001 Check Engine Light is On
Old 21 Mar 2011, 06:21 pm
Default 2001 Check Engine Light is On
My hubby took my PT to Autozone and got the 0401 code for: check EGR. The guys there told me that it may be the EGR valve (which I can get from them) and/or it may be the Transducer (which I have to buy from Chrysler ).
Anyone know which is may be? Both? Do I have to replace both? Can I clean either of them?
I am assuming I will not pass the emission testing for my license plates until this has been resolved?
Old 21 Mar 2011, 09:38 pm
Default Re: 2001 Check Engine Light is On
Probably just the EGR. Found this on PT Do-It-Yourself.net (Pay site)..
P0401 (M) EGR System Failure - Required change in air/fuel ration not detected during diagnostic test.
The P0401 is a very common code for the EGR. More than a few have been replaced under warranty on the PT. A new valve should cure the codes. Make sure you follow the SM OE replacement instructions precisely. If you don't have a manual, you can find the OE procedure in the Pit area on the site. Once it's replaced, the code won't clear itself using the battery disconnect technique. Have the dealer clear it using their DRB scan tool during your next visit.
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Check Engine Light MedicAsh Tech & Performance Forum 6 29 Jan 2011 02:54 am
check engine light wednesday General PT Cruiser Discussions 8 31 Dec 2010 02:42 pm
check engine light azphotog Tech & Performance Forum 3 13 Feb 2010 11:45 pm
Engine Check Light IRPT Tech & Performance Forum 11 27 Jun 2004 10:24 pm
