Wont start after timing belt change. Help!
Old 23 Mar 2011, 05:43 pm
Default Wont start after timing belt change. Help!
Well I put on a new timing belt after the last one broke. Put on a new water pump while I was in there and gave it a tune up. Put it all back together and now it won't start. Doesn't act like it wants to start. Found out how to check the codes and it showed the 1684 and 1282 codes. Well we went and bled the fuel rail just in case and I swapped out the fuel pump relay and disconnected the battery for a bit. Still nothing and no codes now. Any ideas please? I'm lost on what to try next. We are getting fire to the plugs I know that much. Thanks for any help you may have.
Old 24 Mar 2011, 01:05 am
UptownSport's Avatar
Default Re: Wont start after timing belt change. Help!
Fuel Pump Relay Control Circuit
My guess is it's timed wrong-
ASD or whatever it's called won't turn on if it doesn't have a crank signal
or (some years of Neon) doesn't show Cam and crank sensor in sync.
Old 24 Mar 2011, 09:53 am
If you moved your crank at all while replacing your belt you can put the crank sensor out of sync. Both crank and cam sensors are set to be in sync so that timing is accurate. If not, it won't fire up.
Old 24 Mar 2011, 10:54 am
Thanks everyone. I'm gonna check it again to make sure we aren't 180 out on the timing. I had one heck of a time getting the crank dampener pulley off so I'm not looking forward to getting back into it to say the least. Maybe the second time around it won't be so difficult.
Old 24 Mar 2011, 11:57 am
cruserdad1976's Avatar
id say its out of time they are a pain to get in and 1 tooth will make a diffrence
Will not start after timing belt change. britt Tech & Performance Forum 14 29 Oct 2013 12:44 pm
After timing belt wont start moparman75 Tech & Performance Forum 1 17 Apr 2011 10:39 am
2001 Pt timing belt replaced..now wont run right! keller Tech & Performance Forum 8 22 Feb 2010 04:33 pm
Timing belt change turbomangt General Turbo Discussions 31 19 Jan 2009 04:48 pm
Timing Belt change calflan Tech & Performance Forum 1 23 Oct 2007 03:52 pm
