Why does my pt shake?
Old 23 Mar 2011, 09:47 pm
Default Why does my pt shake?
It starts shaking after I get Passed 65 and I don't know what it is from!!!
Old 23 Mar 2011, 10:01 pm
Default Re: Why does my pt shake?
Check the balance of your wheels.
Old 23 Mar 2011, 10:13 pm
I'll second that. How old are your tires to. I bought a car that had been stored for some time and the tires came apart from under me while I was driving. Its like theres a knot or lump in the tire when this happens. Out of ballance will have a similar feel to it. Look closely at your tires to see if every other tread ridge is higher than the others and if so then ballancing your tires will likely fix the issue.
Are there any minor rumblings while accelerating? If so look at your motor mounts.
John
2006 Base. No mods yet. Purchased 2/2011 and in need of some TLC.
Old 24 Mar 2011, 05:42 am
Popeye77's Avatar
Hi bhunt41,
I had the same problem 4 months ago.
When I was driving from 100-110km/h (65-70M) my PT started to shake.
It kept shaking when accelerating, then reduced when I stopped accelerating.
I first check the front tires, and found them not good anymore.
Got the tires changed, balance & alignment adjusted.
Everything solved.
If in your case your tires are ok (shape and pressure), as advised by Crewzin, check then the balance and alignment of your wheels.
Hope this helps
Cheers, Popeye
Ride where you see....die where you have to die.
PT Cuiser 2.0l Auto Black "STARTECH by BRABUS"
Startech sports chassis, dampers & springs
Startech sports exhaust, dual oval tailpipe
Startech sports steering wheel
Startech aluminium pedal pads
Startech entrance panels chrome-finish
Some additional chrome on the ouside
Carbon Dynamic Air Intake "Kosei"
Wheels Momo 18" - 225x40x18 front - 235x40x18 rear
Front End Shake scatgo General PT Cruiser Discussions 7 06 Dec 2010 08:47 pm
Front end shake THANKS tony General PT Cruiser Discussions 5 08 Feb 2003 02:39 am
Front end shake tony General PT Cruiser Discussions 8 04 Feb 2003 10:59 pm
2002 Crusier Front end shake American flyer Tech & Performance Forum 3 09 Oct 2002 03:26 am
