GAs Mileage MUCH worse after tune up
Old 26 Mar 2011, 12:25 am
Default GAs Mileage MUCH worse after tune up
So I got a tune up, new spark plugs, wires and the throttle body and fuel injectors were cleaned (car was idling roughly at a stop). It idles beautifully now.
And my gas mileage is WORSE than before the tune up! Why would this be--it should be better, right?
I am on my first tank of gas--and it is now at 1/4 of a tank and I have only gone 150 miles (mix of highway and city). I used to get around 280 miles out of a tank. Aint no way it is going to get another 130 miles out of a 1/4 of a tank. I know this is not the way to calculate mileage, but since the tank is not empty yet, I cant give you a real number--however, the difference is noticeable. I first noticed it last week, when it seemed like I was at the gas station way too soon after the last fill up. (04 Limited, Turbo and auto trans)
So did they not adjust something right? What could be wrong? With gas at $4 a gallon, I cant afford this nonsense!
--2004 Limited Edition Platinum Series--
Old 26 Mar 2011, 12:52 am
WolfmanG's Avatar
Default Re: GAs Mileage MUCH worse after tune up
do you know what they gapped the plugs at? Did they have to take off the throttle body? at idle what r your rpms at? what kinda wires did they replace them with? When you got the car, was it new or used?
-Danny Wolfman G
Old 26 Mar 2011, 01:46 am
I have no idea, that is what I pay them to know The car was two years old when I got it and mileage was okay before the tuneup.
Old 26 Mar 2011, 09:31 pm
mdfrodolives's Avatar
Purple, go ahead and fill up the tank again--fill till the pump stops automatically, then fill real easy on the gas pump handle till it stops again. Record your PT's mileage the moment you're finished filling the tank. Then drive the car around till you get to around a half tank.
Now go to the gas station again and fill up the tank--then easy-does-it--squeeze in more gas till the gas handle stops pumping a second time.
Now record the mileage on your PT. Compare this last mileage figure with the mileage figure you recorded on the last fill-up. Let's say you went 150 miles.
Now look at your reciept from the gas station and find the amount of gas you pumped into the PT this last time. Divide your latest mileage by the number of gallons of gas you just pumped in. Let's say it's 10 gallons.
This will give you a true figure of how many miles you're getting per gallon.
In other words, divide 150 by 10. Your figure would be 15 miles per gallon.
Tim
Old 26 Mar 2011, 09:35 pm
cruserdad1976's Avatar
what he said is the best to get a good bench mark as to what you are actually getting what does the readout on PT say you are getting???? you really cant go by miles unless you know the gallons used
Old 26 Mar 2011, 10:30 pm
WolfmanG's Avatar
either that or you could use Fuelly | Share and Compare Real World MPG
-Danny Wolfman G
Old 27 Mar 2011, 09:40 am
yes fulley s great and it still gives you that REAL number
Old 27 Mar 2011, 05:56 pm
Or ... just divide miles by gallons. Seems to me that's simple enough ....
Tim
Well, now I gone and done it: For better or worse, no more springs! Candyman Wheels, Tires, Suspension 18 15 Jul 2009 04:11 am
180 deg. stat- worse MPG? littleblueGT Turbo Performance 8 05 Feb 2007 01:38 pm
For better or worse! Musicman The Detail Shop 3 01 Apr 2006 10:43 am
This is worse then christmas ptgt2point4 Stage Turbo Kits 9 16 Jun 2005 11:50 pm
