Head gasket ?
Old 27 Mar 2011, 01:39 pm
Default Head gasket ?
My wife has a 2001 2.0litre auto cruiser.
It seems to use not leak water, always low or non exist coolant in the separate coolant tank. Heater now blowing cold air and bubbling noise in the engine. It doesn't over heat ever but I don't know what's wrong with it, either air lock or head gasket how do I find out if it's one or the other, thanks
2001 PT Cruiser in Navy blue with just a few chrome touches.
1997 Mercedes E230 Estate in Silver
Old 28 Mar 2011, 03:25 am
swanjack's Avatar
Default Re: Head gasket ?
Mine was the same, head gasket had gone. Take a look at one of my previous posts. Cooling system fault
Old 28 Mar 2011, 08:18 am
besides the obvious external leaks in the cooling system there are also internal leaking possibilities. The coolant leaks into the cylinders and is burnt up under normal driving. Usually boiling or bubbling of the coolant in the radiator ro coolant overflow tank is from gases being blown up from combustion chamber. Resolution would be to replace the head gasket, unfortunately. A compression check between cylinders will identify where the leak is.
Old 28 Mar 2011, 04:33 pm
While you do not see the white cloud as we did years ago before the cat converter vaporized the water and steam, the cat can not hide the smell. Put some antifreeze in and see if you can smell a sweet acrid smell from the exhuast after warming up.
I drove my 95 Sportage with a blown gasket for almost a year smelling just a whiff of antifeeze only when stopped a long time occasionally. It was brought about by an oil change place nicking a cooling line which blew 3 days later, dealer replaced line but must not have check gasket as I requested. This car did all the things 4x4safari said with regards to radiator.
12 Regal Turbo
06 PT - Base with BLING! TRADED 5/27/13
01 PT LE - Kid's Car - TRADED 01/13
01 Beetle Sport - SilverSport - 150+ MPH
93 Del Sol - 32+ MPG
90 F150
73 Mach1
Head gasket ? bds02pt Tech & Performance Forum 33 29 Sep 2011 08:30 pm
head gasket how to tell if bad BeagleDad Tech & Performance Forum 18 18 May 2010 09:53 pm
head gasket broadleaspeaking1 General PT Cruiser Discussions 1 27 Mar 2008 05:44 am
Head Gasket Leak?? cruisrman General PT Cruiser Discussions 7 23 May 2005 10:50 am
Head Gasket Kirby Stage Turbo Kits 7 04 Nov 2003 10:59 pm
