2 Questions; radiator line wrench size, stop leak.
Old 30 Mar 2011, 06:32 am
Default 2 Questions; radiator line wrench size, stop leak.
I was wondering if anyone has the size of line wrench needed to remove the radiator from an 02' Cruiser (non-turbo). Question number 2...has anyone used anything in their motor to seal up the head gasket for a temporary amount of time (if they even make anything)? Also (I guess 3 questions); is it ok to drain the freon yourself or do you really need a "mechanic" to drain it?
I found oil in my coolant; my oil was WAY too full and smelled like coolant...I'm guessing 100% sure that I'll be changing the head gasket soon right? A friend that is a mechanic said not to jump the gun and it might be soemthing else...any ideas?
Old 30 Mar 2011, 08:18 am
UptownSport's Avatar
Default Re: 2 Questions; radiator line wrench size, stop leak.
Unless you inadvertently added coolant to the engine ...
Don't continue to run the engine in this condition.
Old 30 Mar 2011, 11:47 am
Ha-ha! No coolant was added to the engine.
Didn't plan on running the engine any longer...really starting to get it from both ends; one end is from the car having more shit broke with it than I had hoped for and the other end from the wife being impatient.
Any idea on the specific line wrench needed for the radiator?
Old 30 Mar 2011, 01:27 pm
Line Wrench ... are you talking about the Automatic Transmission Cooling lines???
I have a standard in my 06 so I can't really check and the kids 01 with Auto is many miles away so I can't check, just trying to figure out what you are asking for so someone else can just answer you.
12 Regal Turbo
06 PT - Base with BLING! TRADED 5/27/13
01 PT LE - Kid's Car - TRADED 01/13
01 Beetle Sport - SilverSport - 150+ MPH
93 Del Sol - 32+ MPG
90 F150
73 Mach1
Turbo oil return line leak littleblueGT General Turbo Discussions 7 24 Apr 2016 10:29 am
Oil feed line leak to turbo PTCruisinTurbo General Turbo Discussions 1 30 Dec 2013 01:31 pm
pin hole leak at turbo's coolant line pppt03turbo General Turbo Discussions 1 21 Aug 2009 12:08 pm
NEW 2007 Cruiser had a leak in fuel line stacigw General PT Cruiser Discussions 1 20 Nov 2007 09:52 pm
Oil Cooler Line leak dpj450 General Turbo Discussions 1 24 Jul 2006 03:50 pm
