08, no start.
Old 31 Mar 2011, 04:59 pm
Default 08, no start.
Lights, radio work.
Have it on a charger with a 50 amp push/charge.
No turn over, no clicking. I can hear the fuel pump priming.
going to try the "Jiggle the key and shifter" thing to see if that works.
Wife drives the car, it's her's. totally stock.
Other than this there was only a bad wheel bearing.
Been a great car.
I've done a search, there has been a few threads with the same issue.
No one has posted a fix or "go-around". (at least that I could find)
Old 31 Mar 2011, 05:26 pm
Default Re: 08, no start.
Do any searching of the other posts before you started your own without even saying "hello" ?
Old 31 Mar 2011, 05:41 pm
Hmmmmm, Hello! hows it going guys?
Sorry, got focused on the issue.
I'm used to going on one of my other "car forums" and asking questions.
Been a long time member over on Regalgs.org.
Old 31 Mar 2011, 05:49 pm
Better. So, have you looked at some of the other no-start threads on the forum. Here's some...
05 pt will not start
Newbie w/dead PT
So, I have a dead PT Cruiser in my driveway...
PT starter problems
Old 31 Mar 2011, 05:50 pm
Move the steering wheel up & down while turning the key and starting the PT.
Old 31 Mar 2011, 05:54 pm
So, went out tried the "jiggle" no workie.
Plugged in the OBD scanner, showed a P303 code = iirc misfire on Cyl #3.
Meh, ok,....from not starting.
Cleared the code.
Car starts......Um....OK??!! thats weird.
What we think happened, She left an interior light "or something" on when she came home from work this morning.
Killed the Battery just enough to create a no start situation.
( ECM's are sensitive to voltage drops)
With that failure and Very damp, wet snow rain today here in Buffalo NY.
Caused the "P303 code" to Pop the Mil light and fail the car to start.
I'm not really familiar with the inner workings of the PT Cruiser as I am with my car.
Any one care to chyme in to help me understand What the hell just happened.
Old 31 Mar 2011, 06:09 pm
You did say you had it on the charger so maybe you got enough voltage to get the starter going. It's needs 11+ volts to turn over. if not, other things work (lights, radio) but just not enough to get it to turn over.
The P0303 code is something else and shouldn't have prevented it from starting. Your guess on the better half leaving something on is probably a good one.
Old 31 Mar 2011, 06:27 pm
Yup, did that too. Nada...
Old 31 Mar 2011, 06:36 pm
had nothing before clearing code, then it started right up.
Shut it off and restarted several times no problems. (crosses fingers)
HELP!! It won't start! lcarsx32 Tech & Performance Forum 12 29 Jan 2011 02:34 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
What a way to start the day!! Knotsobright1 General PT Cruiser Discussions 7 06 Oct 2009 12:00 am
car won't start sonny562 Tech & Performance Forum 7 16 Aug 2004 08:14 am
Where to start??? ptdreamer Turbo Performance 9 30 Jul 2004 11:12 am
