error code P1652
  • 1 Post By CREWZIN
Old 02 Apr 2011, 05:36 am
Default error code P1652
Hi
can someone please help me out i have an error code P1652
i looked it up and it says "P1652 Powertrain Induced Chassis Pitch Output Circuit"
does anyone know how to deal with this ??
thx
Ronny ,Belgium
Old 02 Apr 2011, 06:35 am
Default Re: error code P1652
Ronny, welcome to the forum. You didn't say what kind of trouble your having.
I found this in a search. Looks like you need to find someone with an OBDII scanner than can pinpoint the problem.
Trouble Code: P1652
Serial Communication Link Malfunction
Trouble Code Conditions: Engine started; and after the TCM did not detect any signals on the Serial Communication Line for more than 20 seconds. Note: Due to the integration of the PCM and TCM, Bus communication between the modules is internal.
Possible Causes:
TCM cannot communicate with the Instrument Cluster (MIC)
TCM cannot communicate with the Powertrain Control Module
PCM/TCM is damaged or it has an internal failure
grandads_shed likes this.
What does the error code PO 138 really mean? TheFox General Turbo Discussions 8 15 Jul 2012 10:10 pm
is it an error Code or something else saraPT04 Tech & Performance Forum 5 08 Oct 2010 02:46 pm
Error Code 320 okla2001pt Tech & Performance Forum 1 17 May 2010 12:42 pm
error code... superpug666 Tech & Performance Forum 16 13 Oct 2009 07:33 pm
Error code?? whiteknight Tech & Performance Forum 3 15 Mar 2008 10:29 pm
