no 3 or 4 gear
Old 03 Apr 2011, 11:05 am
JaviPTGT's Avatar
Send a message via Yahoo to JaviPTGT
Default no 3 or 4 gear
My car won't shift in 3 or 4 gear I got code p0733 and p0734 they said to chAnge the
: transmission control solenoid I just want to know if that's will fix it I have a 03 gt auto stick any help call me 5743002132 or text thanks
Old 03 Apr 2011, 11:33 am
Default Re: no 3 or 4 gear
Originally Posted by JaviPTGT View Post
My car won't shift in 3 or 4 gear I got code p0733 and p0734 [B]they[B/] said to change the : transmission control solenoid I just want to know if that's will fix it I have a 03 gt auto stick any help call me 5743002132 or text thanks
Why do we need to call or text, that's part of what this forum is for.
Who is "they" that told you ?
According to PT Do-It-Yourself, the problem could be the solenoid, module or it could be an internal problem. Did "they" have an OBDII scanner to help pinpoint the exact problem or just find the codes for you.
Old 03 Apr 2011, 11:48 am
JaviPTGT's Avatar
They dealer so I just want to make sure I took the tranny pan off and no shavings and my tranny fluid was a lil black and smeld like burn bread I got some bolts on and the 93 dsp tune on it so is this a commen thing on the autos
Old 03 Apr 2011, 12:07 pm
There are some owners that have had problems but more people haven't. Usually it's owners that haven't done any preventative maintenance or have used the wrong fluid. No, it's not common.
Old 03 Apr 2011, 12:30 pm
JaviPTGT's Avatar
I bought mine new it has 55k on it and I use Castro edge every 3k and take very good care of it my gf said I love the car more then her but I just want to be sure that part will fix it I see ur from sw Florida I moved from Naples about 4 years where u at
Old 03 Apr 2011, 12:35 pm
Sorry, I'm not in a position to say 100% that the TCS or TCM will fix it. If your having the dealer change one of those parts, ask him if he's 100% sure that will fix it. From what I've seen on this forum about dealers, I don't think they will say it.
You've changed the oil frequently, but your problem is with the transaxle. Have you ever had it changed or flushed.
I moved down to Fla from Maryland when I retired from the Government in 2000. I'm on the west coast about 90 miles above Tampa, 200+ above you.
Old 03 Apr 2011, 12:41 pm
JaviPTGT's Avatar
Nope never did that I'm going to after I change the part and FILTER LOOKS LIKE WE did the the same just backwards
Old 03 Apr 2011, 12:45 pm
There's two theory's on the tranaxle. Drop the pan change the filter every 30,000 or a full flush with a cleaner (that cleans the permanent filter) every 50,000. Whatever, be sure to use ATF+4 fluid.
Old 03 Apr 2011, 01:08 pm
JaviPTGT's Avatar
Ok thanks as long as its atf4 I'm ok or does it have to be the mopar one
Old 03 Apr 2011, 01:46 pm
There's a few different brands of good licensed ATF+4. The list was just updated about a week ago.
Licensed ATF+4 Brands
Won't shift out of first gear Cybergarage Tech & Performance Forum 13 06 Jan 2016 04:13 pm
Car in gear but won't move Nates2001pt Tech & Performance Forum 3 04 Aug 2014 05:00 pm
the most gear in a pt ever? vinister Sound and Security Forum 12 12 Mar 2007 03:03 pm
p0733 Gear 3 Incorrect ratio p0733 Gear 3 Incorr RobGT General Turbo Discussions 12 04 Nov 2004 02:02 pm
Looking for 03/04 GT Gear box Kboom General Turbo Discussions 4 29 Oct 2004 05:00 pm
