ENGINE SWAP
Old 04 Apr 2011, 05:11 pm
Default ENGINE SWAP
i recently swaped an 03 engine into a 04 pt.identical engines.i drove both cars into the shop,of coarse the o4 had a rod knocking but still running.after i made the swap,bolt for bolt,the 04 with the o3 engine in it will not start.ive cleared the DTC's and tryed both computers cuz there both good.and still nothing,i disasembled as little as possible and checked wires & sensors.dose anyone had any clues as to what i might be over looking? thanx
Old 04 Apr 2011, 07:53 pm
Default Re: ENGINE SWAP
I just did a rebuild and had the same problem. Got it running today.
Check to see if you've got the coil pack plug-in crossed with the Camshaft Position Sensor plug-in. They look the same.
I got mine crossed.
After that I could get it to start with starting fluid but could not get gas to it.
Found out the fuel pump went out from just sitting there for a month. It worked fine when I first pulled it into the shop...
Also be sure to check the automatic shutdown relay in the power contol module under the hood, along with the fuel pump relay.
Hope this helps.
Good luck!
Old 04 Apr 2011, 08:49 pm
It it's a turbo model, the 03 has an SBEC controller and the 04 NGC. If they're non turbo, they are both NGC. If that's the case, I'd suggest starting with the basics: spark, fuel, compression, and timing.
engine swap PTcruzer02 General Turbo Discussions 2 17 Jun 2010 10:01 pm
engine swap nimblemotors Tech & Performance Forum 10 01 Aug 2009 02:09 am
02-03 Engine swap brit Tech & Performance Forum 0 13 Apr 2009 12:49 am
engine swap INFERNODPPT Tech & Performance Forum 21 29 Oct 2005 10:00 pm
Engine Swap macster Turbo Performance 3 24 Feb 2004 12:01 am
