Hot Fluid Leaked On Foot Drivers Side. Car Fogging Up. Coolant Bubbling in Reserve.
Old 04 Apr 2011, 06:17 pm
Unhappy Hot Fluid Leaked On Foot Drivers Side. Car Fogging Up. Coolant Bubbling in Reserve.
Please help. My foot was burnt while driving. Hot fluid dumped on my right foot while I was driving. Now the car steams up on the inside and smells like coolant. Then it went away for a few weeks and is now doing it again. What is this?
Please help.
Thanks
Old 04 Apr 2011, 07:32 pm
BladeRunner's Avatar
Default Re: Hot Fluid Leaked On Foot Drivers Side. Car Fogging Up. Coolant Bubbling in Reserv
It sounds like you have a leaking heater core. I would go to a trusted mechanic and have your cooling system pressure tested. I'm sure if you look at your overflow tank..it will be very low or empty. Have you tried to use the heater? If so, I'll bet you will have no heat because the coolant level is too low. If you add coolant you will likely get more leaking inside ..maybe on your foot again!
Get it looked at ASAP.
Old 04 Apr 2011, 07:44 pm
Thanks for the tip. If I put the switch to defrost the steam goes onto windshield, if vent then steam comes out vents... etc...
The other issue I am having is oil in my spark plug wells....
I only have 70,000 miles. Never had a car that had any problems this soon. Bummer. I really like the car though.
Old 04 Apr 2011, 07:54 pm
I suggest you get that looked at ASAP..you don't want to be breathing coolant vapor! Besides, you won't be able to see to drive properly if it's a bit cool in the mornings and you need your defrost!
Tags
coolant
Special engine coolant fluid mstyler05 Tech & Performance Forum 8 19 Jun 2010 12:12 pm
Drivers Side Gets Loud TwoToneTommy Wheels, Tires, Suspension 3 24 Feb 2010 09:12 pm
Some A-hole cut my top on the drivers side MINIHEMI46 PT Cruiser Convertible Forum 21 02 Jan 2010 11:37 pm
Drivers Side Headlight 2k1PT Classifieds: Want To Buy 2 23 Aug 2008 03:39 pm
Coolant Fluid Level Ed Lim Tech & Performance Forum 2 28 Sep 2003 07:38 pm
