a/c power steering belt tensioner
Old 11 Apr 2011, 02:49 pm
swanjack's Avatar
Default a/c power steering belt tensioner
On my 2.0 pt, my drive belt tensioner looks like this PT Cruiser power steering belt tensioner (it's upside down in the photo which doesn't help).
The haynes manual does not give any help on this tensioner, it seems as far as haynes is concerned it doesn't exist. I know that all of you have the 2.4 which haynes covers, but does anybody have any idea as to how you loosen this tensioner so as to get the a/c and power steering belt off. Apart form the tensioner, the 2.0's a/c, power steering and distributor belts set up is exactly the same as the 2.4's.
Thanks in advance.
Old 11 Apr 2011, 03:06 pm
golf55555's Avatar
Default Re: a/c power steering belt tensioner
I think it's a 15mm wrench, just grab the bolt on the pulley itself and push towards the front and slip off the belt.....POC...
SOLD-----K&N FIPK CAI, MSD wires, NGK plugs
03 Dream Cruiser series 2 #1489,5sp
k&N FIPK CAI, MSD 8MM wires, NGK iridium plugs, oil catch can, AGP wastegate, Mopar BOV,Mopar Boost Gauge,Stage 1 injectors,DSP Sport tuner,VSR Anima 18" wheels, Kelly 225-40-18 tires, 3" cat delete downpipe, APS SS dual exhaust.
Now owner of a black CSRT stage 1.
Old 11 Apr 2011, 03:29 pm
swanjack's Avatar
Which bolt head? I don't have one, that's my problem The bolt goes from inside to out and all that's visible in the centre of the pulley as you look at it, is the thread end of the bolt. Do you mean putting the wrench on the bolt head so that the wrench is between the pulley and the engine, then turn towards the front to slacken?
Old 11 Apr 2011, 03:38 pm
golf55555's Avatar
AHHHHHHH..... opps, my bad! guess I should have paid more attention....
Can you get a pipe wrench or bar wedged to remove pressure on the arm? Does it have an allen on it? that pulley has to come off somehow?
Old 11 Apr 2011, 03:41 pm
golf55555's Avatar
put a crescent wrench on the tab just past the pulley???
Old 12 Apr 2011, 03:51 pm
The serpentine belt tensioner on our 2.4's is loosened by inserting a breaker bar into the square opening in the tensioner body and turning the bar. Unless I'm mistaken, I'm seeing a similar square opening in the center of your tensioner, so just insert a breaker bar with maybe a short extension and turn.
Jerry
Old 13 Apr 2011, 06:51 am
swanjack's Avatar
I shall give it a go, cheers.
power steering belt keeps breaking need help gerryff Tech & Performance Forum 35 11 Jan 2013 01:30 pm
power steering belt karo6 Tech & Performance Forum 4 14 Apr 2010 07:52 pm
Power Steering Pump & Serpentine Belt? ChicagoPT Tech & Performance Forum 4 24 Apr 2009 10:51 pm
Power Steering Airconditioner belt noise macster General Turbo Discussions 3 04 Sep 2003 06:54 pm
