Codes?
Old 11 Apr 2011, 09:08 pm
BladeRunner's Avatar
Default Codes?
For the first time since I got my PT back in Oct..well once before ( just a loose gas cap) I have some codes. They were P1604..I think, and 0445. I'm really tired right now..long day, don't ask! I already erased them
Anyway, on my way home after work I only went 3 blocks and got the two codes.
When I got home I put the scanner on it and it said "evaporative system leak detected, cross flow..no flow".
What the heck does THAT mean??
It runs fine, so I hope I didn't hurt anything?
BTW, it's an '01 LTD N/A auto 214,000km.
Old 11 Apr 2011, 09:30 pm
Default Re: Codes?
The loose gas cap can trigger a code between 0442 and 0445 so hopefully thats the problem.
A more serious problem is the other code. Found what it is but not what to do about it;
P1604 PCM Internal Dual Port Ram Read/Write Integrity Failure - Dual port RAM read/write error.
Old 12 Apr 2011, 04:34 am
Default Re: Codes?
Thanks CREWZIN, the gas cap was the first thing I checked.
Old 12 Apr 2011, 07:38 am
Default Re: Codes?
RAM read/write error is when your PCM needs a reboot to clean out it's internal cache. Need to disconnect your battery for at minimum 5 minutes, personally I'd give it 20. While it's disconnected, press on your brake a few times to bleed off any residual power. Should clear the code once you reconnect.
Old 12 Apr 2011, 10:07 pm
Default Re: Codes?
Thanks Chromenut, I have a scan tool, I erased the codes last night and this morning on my way to work they didn't show up,but, tonight on my way home they came back.
I got the #'s wrong last night; 1684 is one & P0455 is the other one when I did the "key dance". When I hook up the scan tool tonight it only shows the P0455 code. I erased it again, I did check my gas cap. The first time the scanner read the code it said it was "evap system gross leak...no cross flow" ..Or something close to that,sorry..I've just worked 30 hrs since yesterday morning..having a MAJOR brain freeze Thanks for the info...
TOO MANY CODES!!! Nonie Tech & Performance Forum 13 20 Mar 2011 12:21 am
obd-II codes Punch General Turbo Discussions 13 06 Jul 2009 06:54 pm
No Codes?? BB General PT Cruiser Discussions 2 13 Aug 2005 08:25 pm
obd codes camarillogolfer General Turbo Discussions 5 06 Aug 2004 11:10 am
