2001 cruiser eginge help please
Old 12 Apr 2011, 10:45 pm
Angry 2001 cruiser eginge help please
My daughter drove her 2001 cruiser with insufficient coolant. She drove it till it died. I had it towed home. Next day i topped off collant tried to start it but it turns over And wont start, it popps a little like it wants to start but wont. It sounds like it is spinning without any comperssion. No water in oil or oil in water.. Could it possibly be a warped head or blown gasket ? Pulled 1 plug and it looked normal. Where do i begin ?
Old 13 Apr 2011, 12:04 am
Default Re: 2001 cruiser eginge help please
Did you check the timing belt. Are the Cams turning? Topping off, how much coolant required to do so? Could be both TBelt and Water Pump. BTW, how many miles on the car?
12 Regal Turbo
06 PT - Base with BLING! TRADED 5/27/13
01 PT LE - Kid's Car - TRADED 01/13
01 Beetle Sport - SilverSport - 150+ MPH
93 Del Sol - 32+ MPG
90 F150
73 Mach1
Old 13 Apr 2011, 10:24 am
Had daughter turn it over, belt is moving. Coolant was pretty much bone dry, 102k miles on it.
Old 13 Apr 2011, 01:52 pm
Okay ... since belt moving that rules out a total failure of the water pump which would have created the no coolant condition and a no compression condition with valves stuck open. At 102K it should have been replace by now. I would most likely say the drive it til it died totally blew out the head gasket or cracked the block or most likely the head. I would run a compression check on it first, then begin tearing it down. I don't think you will be seeing much of the new coolant you put in making it into the oil or oil in new coolant because you have not been able to get it running. Glad I had my kid check the coolant all the time when I bought hers due to some leakage at the thermostat housing which I repaired.
12 Regal Turbo
90 F150
73 Mach1
Old 14 Apr 2011, 03:21 pm
Thanks for takin the time to help, it is really appreciated. Its great to have people with knowledge take a few minutes to post replies. Cheers !
Tags
blown engine, head gasket, overheating
2001 PT Cruiser TBURG PTS Classifieds: For Sale/Trade 12 04 Apr 2011 01:00 pm
2001 PT Cruiser getting hot please help!!! jtsebastian Tech & Performance Forum 1 15 Dec 2010 06:13 am
2001 pt cruiser pt_ Tech & Performance Forum 1 17 Sep 2010 11:51 am
