"Break-In Secrets"
Old 13 Apr 2011, 08:50 am
ROCKETMAN8060's Avatar
Default "Break-In Secrets"
I was about to change the oil in my bike and I found this! What do you think?
Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
ROCKETMAN8060
Old 13 Apr 2011, 10:59 am
Dino's Avatar
Default Re: "Break-In Secrets"
I don't know, I always ran my my bike hard though
Old 10 May 2011, 06:58 am
LOL!!!
ROCKETMAN8060
Old 10 May 2011, 07:09 am
"There's a very small window of opportunity to get the rings to seal really well ... the first 20 miles !! "
Why?
He has a theory, and that's fine....
"More Power & Less Wear" -
Also cures bad breath.
Old 10 May 2011, 08:38 am
UptownSport's Avatar
there are different types of rings, painting them all in a broad brush doesn't seem right.
Cast Iron ('Quick seater')
Chrome
Moly
perhaps more
What does sealed power say?
We were always told to use light oil (ATF for piston assembly, it's 5w)
The first moments are intense heat- the rings are, as mentioned, grinding
the high spots off. Localized (The ring) gets too hot at extreme RPMs.
His procedure does sound the same as what direct connection / mopar performance recommended, IIRC, so there's nothing radical there
Old 10 May 2011, 02:09 pm
chris15's Avatar
I followed that site when I broke in my new motor. The motor's fine, unfortunately the transmission is not.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 10 May 2011, 02:14 pm
RaineMan's Avatar
All that "break in" stuff is a load of crap.
Engines are run for a pre-determined amount of time at the factory to make sure everything is put together properly. Then you also have to figure the vehicle is driven onto the trailer, off the trailer, around the lot and probably test-driven by a few people before you buy it... nobody gets a vehicle with zero miles on it.
The only possible way you'd get to "break in" an engine is if you build one yourself.
Old 10 May 2011, 06:04 pm
The factory, I have no doubts, has mastered breakin, through components, process and lubricants.
I read the article from perspective of one about to replace (Hopefully only) rings
Stalling, rough idle, running "hard", hesitation LiLOrion Tech & Performance Forum 36 21 May 2013 12:43 pm
2002 Pearl Almond Limited Pt "Custom Route 66 " Edition rt66pt Classifieds: For Sale/Trade 59 04 Mar 2013 12:49 am
Can you "break" the A/C Pump Lotus14 Tech & Performance Forum 10 16 Dec 2010 05:44 am
Turbo "phhsssss" or "whoosh" sound--Normal? Silenceable? Help! Memark General Turbo Discussions 13 24 Nov 2010 10:56 pm
Part number for "PT" door emblems on 2008 Dream Cruiser 5 gpr75 General PT Cruiser Discussions 6 16 Jul 2010 12:15 pm
