Vibration!!!!
Old 18 Dec 2003, 04:33 pm
Send a message via AIM to 2003ptcrusierbrusier
Default Vibration!!!!
[:I]I have a stock 2003 Crusier and it has started vibrating while in reverse and i have taken it to two shops and they say its normal
wondering if anyone else has had this problem and got it fixed????[:0]
Old 18 Dec 2003, 04:54 pm
Welcome to the forums.
Go somewhere else. If it's normal, why did it just start doing it?
Have dealer go over transmission carefully.
If THEY say it's normal, ask to drive the PT demo - I'll bet it won't do it.
Old 18 Dec 2003, 05:12 pm
2003ptcrusierbrusier, welcome to the forum, ditto what quicksilverdon said. You did not say if the shops you took it to where Chrysler dealers?
2002 Inferno Red PT Limited
Mercedes Wiki
Old 18 Dec 2003, 06:12 pm
[xx(]I did take it to dodge dealership two different ones and they said they test drove the demo and all 03 crusiers are that way.....it did have trans work done before because of leaks....
Old 18 Dec 2003, 08:14 pm
Send a message via AIM to macster
Mine doesn't vibrate and its lowered with a 2.5" exhaust. Something is wrong.
macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
Old 26 Dec 2003, 05:29 pm
Send a message via AIM to Rolo
No, mine is smooth. It seems like something may be slipping internally. Is it auto or stick?
Old 26 Dec 2003, 08:17 pm
"they say its normal" yea right what a bunch of crap!! if you have a friend or someone that knows someone in a repair shop take it to them!! and also call chrysler direct and make sure you do that!!
Old 31 Dec 2003, 06:33 am
I test drove an '03 Gt autostick the other day, it had a vibration in the steering wheel, at say 20-45 mph the wheel shook, I told the salesman, and even showed him the wheel shaking, he said he'd have it fixed, but this all was in drive, not reverse. The GT had 11k on the odometer and the tires seemed low in the front, but, if it was to be fixed, there gonna call me in for a second test drive, Maybe I'll end up with a black 03GT, whoknows what the other dealer's gonna do, the one who's had my deposit for 90days and can't finance me, but won't give me my $$ back.
Hope the New Year 'sorts' it self out, soon. Happy New Year to yaall
\'04 GT w/auto stick, tinted, remote start, boost guage, BTG exh.,seatcovers, armrests,sunroof,.........
Old 05 Jan 2004, 08:45 pm
Try the lower engine mount.
It will vibrate really bad untill it gets worse.
Put the E-Brake on w/ the hood up and put it under a load.
In drive. I mean give it the gass while somebody looks at the
motor. If it moves alot then that's the problem.
LOWER MOTOR MOUNT.
I found out the hard way. Part costs about $45.00
Easy to replace with a shop lift & a trany jack.
Two bolts.
2001 Stone White PT (Non-Turbo)
http://www.imagestation.com/album/?id=4288162929&idx=1
Click Here to see my PT!
harmonic vibration rszappa1 Wheels, Tires, Suspension 17 15 Feb 2006 11:39 am
vibration causing dash to rattle Easymover Tech & Performance Forum 3 26 Jan 2006 07:34 pm
40 to 60 mph Vibration Update fixed gtbright General Turbo Discussions 5 05 Sep 2005 06:51 pm
Steering Vibration qimoves Turbo Wheels/Suspension/Handling 6 12 Jun 2005 05:45 am
40-45 MPH Vibration in a new '02 PT Automatic Mopar Madness Tech & Performance Forum 14 31 Jan 2003 11:44 pm
