Screw turns, but won't come out...?
Old 18 Apr 2011, 01:30 pm
Default Screw turns, but won't come out...?
Hey all, I'm having extreme difficultly (in Pt 2003 Gt turbo), and I mean extreme, of getting a screw out. The screw holds the drivers sit to the floor and is on the left top corner just beside your left foot if you were to be sit and driving. I was able to unscrewed the other 3 screws but that one is the problem it won't come out! I've tried prying it out with all of my force, hammering at it to strip the screw and pull it out. Anyone know how i can get this thing out? I've spent over 2 hours trying to pry and unscrew and get it out. I'd really appreciate it. Thanks!
Old 18 Apr 2011, 01:44 pm
Default Re: Screw turns, but won't come out...?
Got a dremel? To me sounds like you're going to have to cut it out.
Old 18 Apr 2011, 04:47 pm
I would be able to cut only the head of the screw....but the body of the screw would be in there...how would I remove the body after?
Old 18 Apr 2011, 04:50 pm
Once you lift off the seat you'll see the body of the screw extending above the surface, should be able to grab it with vice grips and pull while turning to try and remove it. If it's a body bolt, that's supposed to be part of the body and not turn, then you'll need to get someone underneath to hold that while you try to remove it from above. Shouldn't be turning at all.
Old 18 Apr 2011, 04:56 pm
Pulled up the parts breakdown and the nut for that seat will not be seen underneath, if the drawing is right. If you cut the head off, you can lift out the seat and get to the nut and screw to replace it.
See the parts breakdown in this snippet from the manual:
Old 18 Apr 2011, 04:59 pm
Once the seat is out, cut a slot in it and use a screwdriver to screw it thru to the bottom of the car.
Old 19 Apr 2011, 11:54 am
thanks alot thats what I needed...I will get the dremel and cut the screw...
SCREW SIZES BKLYNMATT Interior Accessories Forum 1 30 Aug 2010 08:45 am
Did I screw up? stu88 Tech & Performance Forum 1 31 Jan 2010 03:03 pm
Chrysler 2002 Maintenance Screw Up chuck45 Tech & Performance Forum 0 23 Mar 2009 01:30 pm
Is Chrysler trying to screw me? biggus127 General PT Cruiser Discussions 8 30 Aug 2007 07:23 am
Plug & Wire Change Screw Up???? BB Turbo Performance 12 24 Feb 2007 12:15 am
