2001 cruiser problems
Old 18 Apr 2011, 03:12 pm
Default 2001 cruiser problems
ok so ask me what you need to in order to clarify the issues that im having with my cruiser. Its a 2001 with the 2.4 and it has roughly 141000 miles on it. It is using coolant fairly slowly (usually have to put in between a quarter and half every 2 months or so). When idling (depending on the day and how long the car has been running) i can see smoke or vapor coming from under the hood but the car is not overheating. I can also smell antifreeze if this happens. If i go for some time without refilling the radiator the heat gauge shows that the car will start to overheat and then go down well below the halfway mark. The waterpump has been replaced a few months ago so i am ruling that out but i am not sure what ielse it coule be (hoping not a blown head gasket but it may be that way)
Old 18 Apr 2011, 04:01 pm
Default Re: 2001 cruiser problems
If you can see smoke or vapor and smell anti-freeze, you probably have a small leak that dripping onto something very hot and causing the smoke or vapor. Take it to a shop that can do a pressure test on the cooling system. That should show you where the coolant is going.
Old 18 Apr 2011, 04:07 pm
Excellent How-To on a cooling system pressure test:
Originally Posted by BostonBob
Testing the coolant pressure
Internal Coolant lost, external coolant lost, white smoke, coolant rising in expansion tank with brownish color, lost of oil, oil level rising, color of oil changing, engine temperature rising (Especially at high speed / freeway). These are all symptom of a head gasket or coolant system failure.
This can be tested with a leak down test and / or a coolant pressure test.
Note: Contrary to popular believe, an engine produce more energy (and heat at the same time) at high speed (freeway) than at idle or slow speed. So more adequate / perfect cooling is needed. Pressure lost often happen in that condition.
The problem “could be” that pressure is building up in the cooling system. This is due to the head gasket (the 2 round one found each side) at the top of the cylinder leaking compression. If the to bottom inner round gasket fail, you will mostly get coolant in the engine oil or oil in the coolant. Normally this symptom happens when the engine is cold but if you have a major leak at the inner head gasket this will happen at any temperature. When I did my heads I had more than 15lb of pressure in the cooling system. So that means that my inner head and outer head gasket had failure (I had a small leak on the right side). The following are a summarization of 2 tests I found a year ago on Boston Bob engine web site, they are reliable test (test it myself). Remember that the coolant flow is low even at high RPM. The more the engine rise in temperature, more the pressure is high.
TEST #1: Pressure Tests for the Cooling System
The first test of the cooling system is done when the engine is cold. A cooling system pressure tester can be installed in place of the radiator cap. Pressure in the cooling system and hot coolant are not something to be treated lightly. Use caution, and never remove the radiator cap from an engine that has been run even for even a short time. After installing the gauge, pump it up to 10 pounds. Look around for leaks if the gauge shows any pressure loss. Common trouble spots include heads, hoses, water pump and rear heater core. If you smell something sweet when you turn the heater fans on, it may be a coolant leak at one of the heater cores, or simply the O-ring at the rear heater valve leaking. Because there is often more then one leak in the system, it is necessary to continue pressure testing until the system holds pressure.
TEST #2
Start the engine cold with no pressure indicated on the gauge. The pressure in the cooling system builds to aprox 7 lbs at normal running temps looking around for leaks. But if the pressure builds quickly to around 15 lbs the pressure is coming from one of the cylinders through the inner head gasket. This can also show up as a coolant pressure loss in the first test. In extreme cases the cylinder can fill with coolant, and will not turn over. This is know as hydraulic lock, and if you suspect this pull the spark plugs and tries to turn the engine again. Pulling the plugs from the engine allows water to escape from the spark plug holes.
This is simply a suggestion but the first test is easy to do and will tell you right away where is your leak or leaks is.
Old 18 Apr 2011, 04:16 pm
The kids 01 had one of these about the same conditions.
The previous owner must have had a "mechanic" fix a problem in the thermostat/thermostat housing area ... could tell by the brown permatex (I didn't know they still made that stuff) I had to scrape off someone had been there. One of the bolt holes in the plastic housing was messed up where the metal insert goes in and they reused the thermostat, which has the gasket for the whole thing attached to it. Since it was a Sunday I removed and replaced thermostat .... changing plugs also at the time since I was most of the way there.
Get a pressure test on it, it is most likely a small leak. When the head gasket blew on my Sportage it was consuming about half a gallon a day, 50 mile comute both ways with last 10 coming home all stop and go.
12 Regal Turbo
06 PT - Base with BLING! TRADED 5/27/13
01 PT LE - Kid's Car - TRADED 01/13
01 Beetle Sport - SilverSport - 150+ MPH
93 Del Sol - 32+ MPG
90 F150
73 Mach1
New to me PT Cruiser Problems addition413 Tech & Performance Forum 14 24 Jan 2013 10:02 am
2001 Special Edition PT - Common Problems? RMO87 Tech & Performance Forum 9 10 Jan 2012 11:31 am
charging problems with 01 pt cruiser gdxxman General PT Cruiser Discussions 3 11 May 2009 04:59 am
Problems with my cruiser morrisbeer General PT Cruiser Discussions 3 25 Apr 2009 07:52 pm
2001 pt cruise control problems charlieborg General PT Cruiser Discussions 4 23 Nov 2008 11:14 pm
