Ok radiator fan is 5 months old and half working!
Old 18 Apr 2011, 06:02 pm
Default Ok radiator fan is 5 months old and half working!
Ok i have been having problems with the car overheating as of late. So after some investigating i have discovered the high speed fan thats supposed to kick on when running the ac doesnt kick on. I have looked at the suggested fuses and they look fine. Since the radiator fan is 5 months old " old one was replaced due to blade breaking". What should i do next?
Old 18 Apr 2011, 06:36 pm
mdfrodolives's Avatar
Default Re: Ok radiator fan is 5 months old and half working!
Where did you get the new fan? Is it still under warranty? Whether is is or not, you need a new one. Maybe you shouldn't get the same brand if you got it off E-Bay, etc.
Good luck.
Tim
there must be a warranty of some sort on a 5 month old fan.
don't know if you replaced it or had it done, either by the dealer or a shop.
beat by 2 minutes.
Old 20 Apr 2011, 03:56 pm
Ok the part came from NAPA. It was replaced by a local mechanic. Is there anything else i should check? I checked all the fuses and i dont know how to tell if a relay went bad. So if the fan works just doesnt kick into HIGH its totally shot?
Old 20 Apr 2011, 04:02 pm
Invid, the high speed and low speed PT fans on certain models have separate brushes. Apparently, your high-speed brushes are kaput, although your low speed ones are fine.
The fan (at 5 months) seems defective. See if they'll give you a new one. Still, I don't know if I'd go for the same brand, considering the trouble you're going through in so short a time since replacing your fan.
Tim
01 pt cruiser radiator fan not working HELP salteedogg Tech & Performance Forum 14 18 Mar 2012 03:47 pm
After 6 months ownership 2008 wanzewurld General PT Cruiser Discussions 8 05 Aug 2010 08:36 pm
Two Months of Burning up the Road SantaGuy General PT Cruiser Discussions 1 13 Oct 2009 08:58 pm
My wifes second PTC in 2 months.... karlkcfi General PT Cruiser Discussions 5 13 Sep 2009 10:53 pm
3 months to go Lucky7 PT Cruiser Events 0 03 Mar 2009 09:15 am
