Hard shifting and no start fixed
Old 19 Apr 2011, 04:19 pm
Default Hard shifting and no start fixed
This is a 2001 automatic PT Cruiser. This past month the starter wouldn't engage unless the battery was charged overnight until this week when it wouldn't engage at all, not even a click. For six months the shifter became more difficult to move until last week when the starting problem got worse. The console and shifter knob were lifted off and the shift indicator plate was unscrewed so it could be rotated. A paper towel was placed over the end of the shifter cable while a lot of WD40 was sprayed into the shift cable using the long spray tube. Moving the shifter back and forth freed it up and also fixed the no start problem, the shifter wasn't moving forward enough to engage the neutral start switch even though it was in Park. Trying to start the car in Neutral was difficult because the tight shifter would overshoot the place where the switch closed making it appear that the starter was bad. If your shifter becomes hard to move then try spraying the cable with lubricant before it breaks or the car doesn't start. Also see the other part of this problem further down on this post.
Old 19 Apr 2011, 04:49 pm
Default Re: Hard shifting and no start fixed
Nice catch Fastone!
Old 19 Apr 2011, 07:20 pm
Fastone, great tip for those manual tranny's.
Old 19 Apr 2011, 08:24 pm
Not sure if this is the right place for it, maybe we should have Crewzin move it and/or sticky it....
Old 19 Apr 2011, 08:57 pm
mdfrodolives's Avatar
Didn't the OP say it was an automatic?
Old 20 Apr 2011, 08:02 am
It is an automatic as stated.
Old 27 Apr 2011, 07:51 pm
Well after a week of driving in the rain the problem came back, this time the shifter was so tight that the cable popped out of the shifter but it didn't break. I removed the air filter assembly and battery then moved the battery tray out of the way, this revealed the other end of the shift cable which is connected to the end of the shift arm and mounting bracket. The steel shift arm and shift shaft were all rust and the shaft was binding where it goes into the aluminum transmission case. The three mounting bolts were removed that held on the mounting bracket so the shift shaft could be moved regardless of the shifter placement. It was almost impossible to rotate the shift arm/ shaft even with a tool for leverage. Since the shift shaft is mounted pointed up from the case, water can get in there and cause rust which binds the assembly. I sprayed the assembly with penetrating oil and heated up the housing a little to free it up some then used a long wrench to move the arm back and forth. The whole shift arm and shift shaft are now covered in grease to keep any water out and the shifter now moves freely because the grease has gotten between the metal parts. I hope this fixes it for good.
Old 05 Jun 2011, 11:13 pm
Dino's Avatar
My shifter has felt stiff lately and today it didn't start until I pushed up on the shifter also. I'm going to try oiling it up also, thanks for the tip.
Old 22 Aug 2019, 02:43 pm
So you just covered the rod where it mounts on the transmission with grease and oil? How did you get oil between the metal parts? Thanks for any help. Mine STIFF
Old 23 Aug 2019, 07:34 am
Shultzee13, that post is 8 years old and that member is no longer around. As for oiling the shift lever, I'd recommend you remove the air filter and housing, battery and battery tray and remove the shift lever arm. Get some penetrating oil and oil the shift shaft. Then I'd recommend some 3in1 oil and lube it with that. Heat it slightly and put some good grease on it as a protective coating. I'd just use some high temp wheel bearing grease. Why? Because I have it on my shelf. And lube the cable as the op did.
hard to start steve smith Tech & Performance Forum 15 23 Dec 2010 08:36 pm
low vacuum, hard start after hd gasket replacement hondoland Tech & Performance Forum 6 31 Jul 2010 07:41 am
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
2002 pt cruiser 5spd pops out of 5th gear and hard shifting bobby515 General PT Cruiser Discussions 3 03 Jun 2008 08:39 am
Safe RPM shifting? distortedlife Tech & Performance Forum 1 20 May 2007 04:37 am
