Replaced the IAC Idle air control valve? Special tool needed?
  #11 (permalink)
Old 26 Apr 2011, 09:58 pm
Default Re: Replaced the IAC Idle air control valve? Special tool needed?
I also had a problem with my idle control motor valve and since I am a newbie to my car, I didn't know what to do so I had to bring it to a mechanic. The mechanic charged me a big amount and I had no choice but to pay him. Reading the comments in this thread made me realize that it just very easy to check what is wrong with it. Thanks guys!
  #12 (permalink)
Old 27 Apr 2011, 07:05 am
Always check Google for almost anything. Just type in a question and dozens of replies will pop up. If you would have done this with "IAC" or "idle air controller" there would be links to this forum and other places talking about it.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
  #13 (permalink)
Old 30 Apr 2011, 04:25 am
Some people might be interested on what happened so I thought I would post. After googling a bit more, I found Autozone's instructions here( Registration required, I think)
Anyways, they have troubleshooting instructions:
Measure the resistance across the IAC Motor pin terminals.
Is the resistance reading at 9.7 ohms (plus or minus 1.0 ohm)-
If yes, go to Step 3
If no, replace the IAC valve/motor. Perform the POWERTRAIN VERIFICATION TEST.
So I borrowed a multimeter and tested the IAC motor--turns out the resistance was 10.3 ohms so IAC is ok.
I now suspect the rough idle to be due to an incorrectly installed (recently changed) timing belt.
Last edited by worcestersauced; 30 Apr 2011 at 04:28 am. Reason: wanted to make things clearer
  #14 (permalink)
Old 04 Apr 2016, 01:11 pm
uncomn's Avatar
Any conclusion to this story.... Was it the belt or....?
  #15 (permalink)
Old 04 Apr 2016, 01:22 pm
The one with this problem? Last Activity: 01 Jun 2011
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
Special tool necessary for Installing Crankshaft dampner pulley? 2001PTCRUZ Tech & Performance Forum 4 14 Jan 2013 10:12 pm
Oil Pressure Sensor ,What tool is needed outfit Tech & Performance Forum 2 17 Feb 2011 07:01 am
Parts Needed--->Valve Cover and Oil Pan 340x Classifieds: Want To Buy 0 03 Jan 2005 08:28 pm
Any Special Treatment Needed for the GT Turbo? bnbhoward Turbo Performance 9 17 Apr 2003 02:20 am
