Engine light on, code P0129
Old 29 Apr 2011, 09:05 pm
cannesman's Avatar
Default Engine light on, code P0129
Wife just pulled up, said engine light was on. Ran code, came up w/P0129, go figure, that code is missing from sticky. Can anyone help?
No worries, checked the posts more closely (my bad) and got enlightened a bit. Thanks.
It's the wife's PT......but I get to drive it on occasion
2003 Inferno Red GT.........no mods.....stock.
Last edited by cannesman; 29 Apr 2011 at 09:11 pm. Reason: wasn't looking hard enough
Old 29 Apr 2011, 09:57 pm
Default Re: Engine light on, code P0129
Is the car idling rough? Does your cruise control work? Generally this is a fault that you can pull a lead off the battery and wipe it clean, for a while. Let the battery sit disconnected for 5 minutes, hit the brakes a couple times to bleed off any residual charge on the system, then reconnect and see if it's still throwing the code.
If it's idling rough, and still throwing the code, hate to say it but most likely bad MAP sensor.
Old 30 Apr 2011, 10:04 am
cannesman's Avatar
Thanks Chromenut. I'll try the disconnect cable and see if it goes away. I'll let you know how that turns out. Thanks again.
Old 30 Apr 2011, 11:16 am
cannesman's Avatar
That seems to have worked. Disconnected negative side for 10 minutes, reconnected and no engine light, woo-hoo. Now I'm wondering though, what caused light to come on in first place, and should I be concerned or just keep an eye on things for now? Thanks again Chromenut.
Old 30 Apr 2011, 11:59 am
Just keep a eye on it. If it happens again, you may want to dig into it deeper.
Old 30 Apr 2011, 12:06 pm
cannesman's Avatar
Thanks Hooligan for the input, much appreciated.
Old 30 Apr 2011, 12:33 pm
No prob Bro, that is what we are here for.
Engine Won't Start -- Code P0129 nimblemotors Tech & Performance Forum 2 29 Apr 2016 09:45 pm
Engine Light on P0139 code shutterbug Tech & Performance Forum 6 25 Sep 2011 05:49 pm
Engine Light ON - no error code PeeTeeCruizer Tech & Performance Forum 2 23 Oct 2010 02:32 pm
Code P0129 ?? BPfromFLA Tech & Performance Forum 4 07 Aug 2010 05:56 pm
