Who has the better brake rotor?
Old 02 May 2011, 03:13 pm
Default Who has the better brake rotor?
Who has the better brake rotor? I have a Turbo GT. The dealer wants $93 per front rotor. Napa wants $41 per. Is the Chrysler rotor twice as good as Napa’s?
Old 02 May 2011, 05:20 pm
Default Re: Who has the better brake rotor?
Get a set from this guy...They are the best (Check out my album)
cross drilled and slotted rotors and SS break lines
Old 02 May 2011, 06:02 pm
ROCKETMAN8060's Avatar
Or try this guys! They are very good too! Good luck!
Cross drilled brakes upgrade!
ROCKETMAN8060
Old 02 May 2011, 06:26 pm
WolfmanG's Avatar
I've talked to Adam from the rotorshop before. He's a really kool guy. his rotors are zinc coated or something like that and they some uncut. so just let him know if you want slot's or holes, or if you want both, he'll charge you the same price, doesn't matter which design you go with.
-Danny Wolfman G
Old 02 May 2011, 07:33 pm
Adam is the shizzle, he stands behind everything he sells. Always been a great guy!
Old 03 May 2011, 01:09 am
I just put a pair of ATE Premium One rotors on the front of my car with HAWK HPS pads three weeks ago. Stopped great with that combo up front. Last week I put a pair of Brembo 27227 Rotors, not drilled, slotted or any other crap. They stop really great. The also don't make the thumping noise that the ATE's did when braking hard. Sure wish Tire Rack had carried the Brembo's for the PT from the beginning. Anyone want a pair of ATE Premium Ones with 450 miles on them in perfect condition let me know. I am still dealing with Tire Rack support and ATE on the problem, hopefully I can return them.
As for your question, the Napa's are probably Wagner, they used to be a really good name brand, will work fine for non spirited drivers. They are probably made in China. The dealers could be the same, you will have to check it out. The ATE's I have were made in China also, but of a better steel than the Wagners. The Brembos are made in Brazil also of a better steel than the Wagners. I have wagners on my truck from Napa and I use Brembo and Zimmermans on the VW.
12 Regal Turbo
06 PT - Base with BLING! TRADED 5/27/13
01 PT LE - Kid's Car - TRADED 01/13
01 Beetle Sport - SilverSport - 150+ MPH
93 Del Sol - 32+ MPG
90 F150
73 Mach1
Old 03 May 2011, 08:16 am
Napa has more than one part # - they offer different prices - is that their most expensive rotor?
Old 03 May 2011, 09:15 am
Napa only lists one front rotor.
Old 03 May 2011, 09:38 am
Then things changed since I bought mine...
Old 03 May 2011, 12:33 pm
white's Avatar
You can get good Brembo roters or yopu can get cheap Chinese ones. I think you get what you pay for. The Brembos are much heaver and last a lot longer.
E. White
2010 Black over Silver, Couture Edition
how to replace a brake disc rotor - The thing i did cartech468 General PT Cruiser Discussions 3 08 Apr 2011 10:37 am
Rotor squeakage Alex_Clarke Wheels, Tires, Suspension 3 06 Aug 2009 09:24 pm
Rotor replacement and general brake questions purple people eater Turbo Wheels/Suspension/Handling 7 25 Jul 2005 08:54 pm
After market brake rotor question clevelandmike Wheels, Tires, Suspension 6 27 Jun 2004 10:30 pm
Rotor paint?? ElectricBlueGT Turbo Wheels/Suspension/Handling 7 03 May 2004 07:32 pm
