P0760 Shift Solenoid C Malfunction
Old 03 May 2011, 11:43 am
Default P0760 Shift Solenoid C Malfunction
Hello I'm Henry from Germany. I've a problem with the PT Cruiser. its a 2002 2,4 PT Cruiser with A/T.
since some days it change the gear from 2. to 3. only short and than it goes to NEUTRAL and the enginge rpm goes high.
the trouble code is: "P0760 Shift Solenoid C Malfunction"
I change the Solenoid block on the transmision, but the problem is the same :-(
know anyone what this is?
Old 03 May 2011, 12:37 pm
Default Re: P0760 Shift Solenoid C Malfunction
Welcome to the forum. No, I don't know the answer but after some searching, I found a mechanic that helped another person with the same code. It requires a lot of reading, and some test equipment.
Chrysler Questions - my 2006 pt cruiser got stuck in 2 gear and i brought it to - JustAnswer
Old 03 May 2011, 01:26 pm
thanks, but I cant open this link :-(
Old 03 May 2011, 01:31 pm
Maybe it has something to do with where you are or your computer set up. It's too long and many pages of information and drawings to do with the solenoid, control circuit and solenoid packs plus the computer.
Old 05 May 2011, 01:56 am
the solenoid is already changed:-( but the malfunction is the same!
PCM intermitent malfunction Gtcruiserowner Tech & Performance Forum 3 16 Mar 2010 11:32 am
Changed Shift solenoid but still wont shift hawaiian General PT Cruiser Discussions 1 19 Oct 2009 07:32 am
AC malfunction tezz Stage Turbo Kits 4 27 Apr 2004 02:45 pm
ABS Malfunction? spicy pt General Turbo Discussions 6 26 Apr 2004 05:01 pm
malfunction in fog lights bigdaddy2o General PT Cruiser Discussions 9 09 Apr 2004 03:20 am
