2003 PT Cruiser 2500 RPM Limit/Engine Shut Down
Old 03 May 2011, 07:43 pm
Default 2003 PT Cruiser 2500 RPM Limit/Engine Shut Down
I have been reading a lot about the PT Cruiser 2500 RPM limitation. I have a 2003 PT Cruisier with manual transmission that has the same problem. I have notice the following with the car since this problem started:
1. The 2500 RPM limit is not 100 percent of the time. May happen today and tomorrow the car runs fine.
2. It seems to never happen before the enigne has warmed to normal operating temp.
3. The check light may or may not be on prior to the 2500 limit being imposed. If the check light was off it will come on.
4. Shutting the car off and letting it cold for four on more hours hides the problem for a short while.
Possible causes:
It seems no one on this forum has successfully fix this problem. Let me explain why (I think). Many autos now have this limp mode feature (2500 rpm limit) to prevent you from getting stranded when the engine over heats. I believe the ECU thinks the engine is over heating so the ECU limits the power of the engine to prevent an over heated engine. Note: there are at least two engine cut relays. As soon as I find the others this problem can be by passed.
Old 03 May 2011, 08:10 pm
Default Re: 2003 PT Cruiser 2500 RPM Limit/Engine Shut Down
Do the key dance to see if you have any codes so we can get an idea of your problem...Key dance: Put key in ignition, turn it ON, OFF, ON, OFF, and ON...then read the codes...
Old 03 May 2011, 08:12 pm
Ohh when I say ON, do not start the car, just move the key until you see all the lights on the dash
Old 03 May 2011, 10:34 pm
I'll bet it is your Camshaft Position Sensor .... It's a 10 minute job and that included the test drive around the block and the beer after the job is done. Mine behaved the same way when it went out, couldn't get it over 2500 rpm and no power. Get the codes and get the part at the dealer, people have reported having mixed results with electrical parts from other sources.
12 Regal Turbo
06 PT - Base with BLING! TRADED 5/27/13
01 PT LE - Kid's Car - TRADED 01/13
01 Beetle Sport - SilverSport - 150+ MPH
93 Del Sol - 32+ MPG
90 F150
73 Mach1
Old 04 May 2011, 10:43 am
I was going to say the same thing but I just wanted to make sure it's the camshaft sensor
Old 09 Jun 2011, 08:28 pm
did you replace your cam sensor, and did it solve your problem? i am having a similar problem, i am going to change my plugs and wires this weekend and the cam sensor if the wires do not fix the problem.
Old 23 Jun 2015, 09:56 pm
I am having this exact problem with my 03 pt. I just replaced the camshaft sensor and now it starts but it still shutting down at 2500 rpm. So for us it's not a camshaft issue. Help!!
Old 23 Jun 2015, 10:06 pm
Is your engine light on? If so what are the codes?
I would first suggest checking the camshaft wire and connector going to the camshaft sensor.
How many miles do you have on the engine? Has the timing belt been replaced?
If the connector and wire is good then I would suggest checking to see if the new camshaft sensor is bad.
Old 24 Jun 2015, 05:28 am
MJKnight's Avatar
I would check under the car to see if the
wiring harness that runs to the crankshaft
sensor is rubbing the Axel shaft....
(this happened to ours a couple years back..)
..also if you replaced the cam sensor..
you may want to replace the magnet..
I just replaced all 3 items with OEM PARTS ONLY
(cam sensor,magnet & crankshaft sensor)
on our car...
but the car told me each time..
what to replace..with the key dance..
Old 24 Jun 2015, 04:21 pm
soonercruiser's Avatar
Cool Re: 2003 PT Cruiser 2500 RPM Limit/Engine Shut Down
Unfortunately, mine had the exact same symptoms, but it was the crank sensor!
Lots more work to get to.
Not a DIY for me!
Frank, aka SOONERCRUISER,
2011 GWE Dodge Challenger SRT8 as Show Car
2003 PT Cruiser N/A Engine part out Sdale Classifieds: For Sale/Trade 2 18 Jan 2011 04:31 pm
pt blowing fuse to shut off engine ? bruinspt Tech & Performance Forum 2 23 Jun 2009 10:32 pm
PT Cruiser 4 cylinder (non turbo) rev limit DJmart Tech & Performance Forum 8 27 Mar 2008 10:44 am
Engine Shut Off, Will Not Restart Stevearino Tech & Performance Forum 37 18 Oct 2007 11:55 am
The noise engine makes when you shut off? stirfry Tech & Performance Forum 7 26 Apr 2004 06:50 pm
