Leaking red oil
Old 03 May 2011, 11:56 pm
Default Leaking red oil
So I have a slow leak of red oil right under where the transmission fluid pan is. So I assumed that it was the gasket of the transmission pan and replaced that. After replacing it there is still a slow leak. I took it to a shop and after having them look at it found out that they don't work on transmissions. they told me that oil was leaking from the controll box but after doing some research I found out that that is an electrical part that wouldn't contain fluid to begin with. I was told by another friend that it could be the axel seal. Does any body have any idea what could possibly be causing this leak?
Old 04 May 2011, 12:11 am
Default Re: Leaking red oil
Very doubtful it's an axle seal. Hope somebody with an Auto-tranny is going to respond as I've got the G288 manual and never leaked anything.
Old 04 May 2011, 09:09 am
Dino's Avatar
It's most likely the transmission solenoid, it's known to leak. As far as transmission problems go it's cheap to fix. Here are some threads on the subject. Good luck.
PT Cruiser Forum - Search Results
For an butt kicking writeup if your planing to do it yourself the ptcrew has one.
http://www.ptcrew.com/phpBB2/viewtopic.php?t=14722
Old 04 May 2011, 09:41 am
That is the exact symptom mine had. It was the solenoid pack. Swapped it out, problem solved.
alan
Old 04 May 2011, 11:22 am
thanks guys. Ill look into it
Old 04 May 2011, 01:02 pm
RedPT07's Avatar
Is transmission is shifting good probably it's just the solenoid Gasket that you can get it at the dealer for less that 10 bucks.
Go to PTCrew.com - Learn it or Burn it. @ "Mod Bible" section they explain how to change it.
Auto tranny (41te) solenoid pack replacement instructions
Old 04 May 2011, 01:58 pm
RaineMan's Avatar
I was gonna say red = tranny fluid, but it looks like others already beat me to it.
Old 04 May 2011, 07:50 pm
yeah it is really a slow leak... I have been driving it the past few days and it shifts though all gears with out any problems... I carry extra tranny oil with me and check it often so I shouldn't have any problems... I'll hopefully switch out the gasket this weekend when I have more time.
Old 04 May 2011, 09:55 pm
mdfrodolives's Avatar
Js, make sure to check that it's not that plastic to metal piece (I can't remember the exact name of the section) on the automatic solenoid pack. I've read a number of posts that mention this issue. So a new gasket--alone--won't fix the problem in this case.
RockAuto has the whole shebang for pretty cheap--and it's a Borg Warner.
Tim
Tags
fluid, leak, transmission
A/c compressor leaking? captmeach7 General PT Cruiser Discussions 11 10 Jul 2010 04:55 pm
Leaking oil cap? CreepyPT Tech & Performance Forum 3 29 Oct 2009 12:16 am
Oil Leaking kairobsor Tech & Performance Forum 4 30 Aug 2009 01:10 am
oil leaking ptma767 General PT Cruiser Discussions 11 20 Feb 2008 07:42 pm
A/C evaporator leaking ruzz1 General PT Cruiser Discussions 2 11 Apr 2006 01:43 am
