engine light P0301
Old 05 May 2011, 06:45 pm
Default engine light P0301
hello,
i got the engine light on for a few days and got the error code P0301.
after having checked other threads of this forum i changed the 4 sparking plugs and the 4 wires and the coil....
i made the engine light erased but it came back with the same error code.
i noticed that he appeared when i was waiting at a traffic light and disapeared when i was driving without stopping, then it came back again when i stopped.
now it s always on and start flashing when the car is stopped for more than 10 seconds.
what do you think about it ? i think there s a problem when the engine is at idle .
Old 05 May 2011, 06:56 pm
Default Re: engine light P0301
First you need to introduce yourself... and then give us a little more info about your car
Old 05 May 2011, 06:57 pm
WolfmanG's Avatar
hey welcome to the site, but we're gonna need a lil bit more info. What type of engine do you have, turbo or n/a? What year is your baby? what kinda plugs did you use? why did you change the coil? When changing the coil, where did you get it?
-Danny Wolfman G
Old 05 May 2011, 07:00 pm
WolfmanG's Avatar
you may want to fill out your profile too. just go to the link at the top of the forurm that says User CP and then just go through the links on the left hand side of that page.
-Danny Wolfman G
Old 05 May 2011, 07:31 pm
OBD-II Trouble Code: P0301 Cylinder 1 One Misfire Detected
Description of vehicle obd trouble code P0301 - Cylinder 1 One Misfire Detected.
Old 05 May 2011, 09:00 pm
oups sorry,
i'm stephane and i have a 2008 non turbo pt cruiser.
i used champion spark plugs
and the coil i changed it because i got to a repair place and when analazing the parameters they told me it should be this , i bought the new one at advance auto parts.
everything was compatible with the pt cruiser
Old 05 May 2011, 09:03 pm
oh and it has 55 000 miles
Old 05 May 2011, 09:09 pm
One thing you should know is that Chrysler advises you NOT to drive the PT when the engine light flashes.
The MIL (Malfunction Indicator Lights) flashes to alert to serious conditions that could lead to immediate loss of power or severe CAT damage. The vehicle should be serviced ASAP if this occurs. (Owners Manual Page 115)
Old 05 May 2011, 09:11 pm
WolfmanG's Avatar
thanx for the info, it'll really come in handy when some of the other tech guys take a look at this. Before you had the plugs, wires and coil changed, where you having any prob's? did you do this yourself or did you take it to some one?
-Danny Wolfman G
Old 05 May 2011, 09:18 pm
hi, no the car was running fine, and it still does , there is no loss of power nothing,
just this light appearing and flashing when i stop too much long....
i made the spark plug #1 changed by a mechanic to see how to to do it ,and then i replaced the other ones with the new wires and the coil myself, it was easy
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
got a p0301 error code...help bkh67 Tech & Performance Forum 1 20 Jan 2011 06:34 pm
P0301 Code even with new plugs and wires? ottoman Tech & Performance Forum 3 10 Feb 2009 09:07 am
error code P0301 chicagocruiser Tech & Performance Forum 4 28 Dec 2008 06:06 pm
Car Sometimes won't start (oil pressure light & Engine Light) gerardio Tech & Performance Forum 6 18 Jul 2008 08:22 am
