A/C blows warm at idle...
Old 06 May 2011, 03:00 am
Travis2k7's Avatar
Default A/C blows warm at idle...
But is ice cold once I get above 30 mph.
Ideas?
It's the first hint of trouble I've had with the car since I bought it 2 years ago... no CEL and the engine is at normal operating temp.
2006 Limited, Auto, 100k miles
Old 06 May 2011, 07:19 am
Default Re: A/C blows warm at idle...
Travis, sounds like your fan isn't working correctly. No air being blown through the radiator and condenser at idle but when you get going, plenty of fresh air through the front grill.
Cold engine, stand in front of the car, hood open. Start the car and turn on the A/C. Go around front and see if the fan is spinning. My hunch is that's it's not.
You can rewire the fan motor, but a new motor or buy the whole fan assembly for about $100 on eBay and install it yourself with the help of a step-by-step on the forum.
Old 06 May 2011, 09:11 am
I agree, low-speed fan is what I would suspect.
Old 06 May 2011, 09:56 am
Travis2k7's Avatar
Thank you both for the response...
Just tried it and that is exactly what happened... cold engine, started the car, fan was not spinning. The A/C was cold, although I assume that would change once the engine got warm.
Would you happen to be able to dig up a link of what I would need? The car is a 2006 limited, non-turbo, the 8th letter of the VIN is B. (I've seen that requested at auto parts stores)
Not very much interested in rewiring, I'd rather just replace what is broke.
Thanks!
Old 06 May 2011, 11:55 am
Here are a couple links for you.
For the fan assembly.
2006-2008 CHRYSLER PT CRUISER Radiator FAN Assembly | eBay
They are also selling just the motor for the fan assembly but you still have to take the whole thing out to replace the motor and it's about the same price as the whole assembly.
http://cgi.ebay.com/ebaymotors/FOUR-...Q5fAccessories
For taking out the old and replacing. I wrote it for the 01-05 cruisers but should be about the same for yours.
Removing the fan and housing 01-05 PT
Old 06 May 2011, 02:47 pm
Travis2k7's Avatar
Much appreciated :-)
Old 06 May 2011, 06:38 pm
mdfrodolives's Avatar
Wow, guys, if it weren't for our radiator fans, funky motor mounts, and regular maintenance, we'd need no tools at all ....
Tim
Old 21 May 2011, 10:36 pm
Travis2k7's Avatar
Ok, I'm having issues again.
I ordered the fan and had it installed about 10 days ago... I had the A/C checked, was told all was well and it was blowing cold.
Now, I left Georgia on Tuesday on my cross country drive to Washington, and up until that point the A/C had been working fine.
When I left Tuesday it was 60 degrees, and has been 45-65 for the entire trip up until today when I hit Montana and it was 75 degrees. I turned on the AC and it was blowing lukewarm air.
This was the first time I had turned on the A/C since Monday. I popped the hood, turned it on, and the "clicking" sound I have heard in the past (compressor coming on and off?) did not exist...
So my question is, in the 5 days since I last used the A/C, did my compressor mysteriously blow up or did all my freon mysteriously vanish?
Or could it be something else?
Old 22 May 2011, 07:16 am
Hard to say. The first thing you need to do is have the R134a checked for proper pressures. Lots of A/C places will do it for free. Check around.
Old 22 May 2011, 09:34 am
Travis2k7's Avatar
Ok, I'll do that this week. Currently in Idaho and finishing the trip today. One thing I have going for me is the 45-65 degree forecast all week in Seattle, which is certainly a lot different than southeast Georgia.
Still, I want it working it case I need it this summer... Haha!
Will post when I get it checked out.
AC Only Blows Cold While Moving.... Scarlet2003 General PT Cruiser Discussions 33 25 Jun 2017 11:08 pm
AC Blows.. But not cold air. jessica2001 General PT Cruiser Discussions 2 30 Oct 2010 05:05 am
cruiser shakes and blows hot air in idle jujuethan General PT Cruiser Discussions 6 17 Feb 2009 11:46 pm
535whp Srt Blows engine Qiktacos General Turbo Discussions 0 26 Apr 2004 12:02 am
