NGK iridium spark plugs
Old 07 May 2011, 02:49 pm
Default NGK iridium spark plugs
I have these spark plugs and granatelli wires from modern performence. Today i gapped them to.038. I noticed that they do not have crush gaskets to go with them. Are they needed ? Im planning on putting them in today. I have a 03 Gt
Old 07 May 2011, 03:04 pm
mdfrodolives's Avatar
Default Re: NGK iridium spark plugs
Chromer, you don't need the crush gaskets on the PT. But make sure you torque the plugs to 156 INCH pounds (or 13 FOOT pounds) ... same thing.
Tim
Old 07 May 2011, 03:06 pm
Thank you sir, appreciate it.
Old 07 May 2011, 04:14 pm
Use never seize on the threads or when you go to remove them it will be like they welded to the head.
Old 07 May 2011, 04:45 pm
whats the foot pounds on the intake. I have the plastic intake?
Old 07 May 2011, 07:25 pm
If you mean the 5 bolts holding the intake manifold on, the INCH pounds is 105. And don't go over that or you'll regret it.
Tim
Old 14 May 2011, 06:03 pm
Okay, changed out my plugs and wires. Valve cover gasket, im thinking there are gaskets that's in the valve cover for the plugs right. When i pulled the plugs the ends were dry, but the threads had oil on them. Number 1 and 3 hole. Number 1 2 3 nice burn, number 4 a little white. Need to replace valve cover gaskets right ?
Old 14 May 2011, 10:05 pm
They're called spark plug well seals. Go ahead and change them if you like. I had a bit of oil, but let them be. It was no big deal.
Tim
Old 14 May 2011, 11:10 pm
Believe me, if it's a valve cover gasket you'll know! Smoke everywhere, constant smell of burned oil, puddles around the head of the plugs. Doubt very seriously it's that gasket. I think Frodo hit it, I have a similar issue but so light it's not worth messing with it right now.
Old 13 Jun 2011, 06:02 pm
lowered05's Avatar
Too much information!! I am going to change the plugs and wires. I bought the Granatelli wires and am confused as to which plugs and the proper gap for a TURBO.
iridium plugs??? DARK270 Stage Turbo Kits 28 17 Jan 2010 04:02 pm
iridium spark plugs sugees69 General PT Cruiser Discussions 26 13 Oct 2009 07:37 am
Champion Iridium Plugs rszappa1 Tech & Performance Forum 5 06 Feb 2006 08:09 am
Iridium Plugs luvmypt Tech & Performance Forum 9 19 Jul 2004 12:16 pm
Denso Iridium Plugs gsharrock Turbo Performance 2 22 Jun 2003 09:09 am
