Doing timing belt and water pump in a few days. Wish me luck.
Old 07 May 2011, 05:21 pm
Default Doing timing belt and water pump in a few days. Wish me luck.
I will be doing the timing belt and water pump in my daughters 2004 PT Cruiser Touring Edition with the Turbo in a couple of days. I hope I have everything. I have read and will need to read again all the steps. I just hope all goes well. If there are any tips that anyone would like to give me I would appreciate it.
2004 PT Crusier Touring Turbo.
Old 07 May 2011, 06:08 pm
Dino's Avatar
Default Re: Doing timing belt and water pump in a few days. Wish me luck.
Never did one but from what I hear it's not a pleasant job, so good luck. Take pictures.
Old 07 May 2011, 08:17 pm
fabreezai's Avatar
No matter if you line up your factory timing marks, before you take off your old belt! mark you cam, crank and counter shaft gears on them self's and the the side of the block with some kind of grease pencil, paint marker, sharpie, what ever your flavor. to make sure you get it back right! Otherwise you'll have to do it twice! just my 2 cents! that way there is no question whether you got it right, you have 2 different reference points to be sure!
Good luck!
Old 07 May 2011, 09:06 pm
You are right fabreezai...do that and you can do like I usually do: make a couple of marks on each gear and on the old belt, then you put the old belt in top of the new and you transfer the marks....that way you are 100% sure you time is perfect
Also, you don't need to disconnect the AC lines and make sure you disconnect the downpipe and the driver side motor mount.
Ohhh and if you need a Chrysler crankcase pulley tool, you can borrow one from Autozone.....
Old 08 May 2011, 10:36 am
Thanks, I will remember to mark the belt and sprockets before removing the old belt.
XtrmDC2 disconnect the drivers side motor mount? None of the service manuals or steps I have read suggest this. Does it just make it easier on the Turbo's? What is involved to take the drivers side motor mount off?
Thanks.
Old 08 May 2011, 12:12 pm
You need to disconnect the driver's side mount to be able to move the engine to that side, to get move clearance to remove everything...It's only two bolts under the air filter box to disconnect it.
Old 08 May 2011, 02:40 pm
Maybe a silly question, but what's the use of marking the belt???
Old 08 May 2011, 02:52 pm
Let me explain Chromenut: You make a couple of marks on the old belt and on each pulley...then you remove the old belt and you put it in top of the new one and you transfer the marks exactly...then, when you put the new belt, you match all the marks ...that way you are 100% sure you did not skip a tooth and its right on timing...
It's an old trick but I use it all the time...
Old 08 May 2011, 03:11 pm
Here is a better explanation....its for an Elantra but you'll get the idea.
Go to step 4, under the "gear puller" picture.
Timing Belt Change Hints and Tricks (Picture Warning!)!)
Old 08 May 2011, 03:35 pm
OHHHH I get it, okay, gotcha, instead of just marking the block or whatever, mark the belt too. Got it, good idea!!! Never thought of that, if the marks line up on the belt and the block, little chance you're off.
Great idea.
Where to buy Timing belt/tensioner/water pump KalSaint Tech & Performance Forum 4 24 Nov 2011 09:02 am
water pump and timing belt bryanschacht Tech & Performance Forum 3 15 Apr 2011 05:32 pm
TIMING BELT AND WATER PUMP CHANGE?? mjb457 Tech & Performance Forum 20 03 Apr 2011 10:38 pm
Changing timing belt and water pump.... missingwhatsnear Tech & Performance Forum 14 13 Dec 2010 04:22 pm
How much is timing belt/water pump installed by mechanic? BrianW General PT Cruiser Discussions 13 03 Nov 2010 09:19 pm
