Too many Codes and car stops running when she wants to
Old 08 May 2011, 04:04 pm
Default Too many Codes and car stops running when she wants to
I have a 2004 2.4 High Output Turbo that is giving me 7 codes. 0129,0016,0171,0339,0551,0522,1187. I was told that I needed to change the MAP Sensor as we would be driving along and she would just stall out on me. I changed that but I still have the same problem. Now it backfires on me when I try to start it up again. If I let it sit for awhile then we run normal again for awhile. It only seems to happen when I am driving around for awhile. On short drives it runs great. Has anyone else had this problem? How can I find out what it is? I don't want to blow my baby up but I have to get to work. Thanks ladyatwork1
Old 08 May 2011, 04:52 pm
Default Re: Too many Codes and car stops running when she wants to
You have too many codes. If you can't do it yourself, have someone take the negative battery cable off for about 5 minutes to clear the codes and reset the computer. Then drive it to see which one(s) come back. You could have had a couple of them for a long time stored in the computer.
Also it helps us help you if you give us more information about your cruiser. How many miles, what kind of work has been done, has the plugs and wires been changed. Who told you you needed a MAP sensor and why didn't they suggest anything else?
Old 08 May 2011, 05:01 pm
The car only has 58,000 miles on it. I did erase the codes while I was waiting for a reply. Auto Zone told me what the codes were and of the choices I told my brother on the phone he said the MAP sensor. I will go for a ride and see which ones come back. Thanks Well no codes came back in my ride so I will wait till it happens again and see what I get. Thank you again for your help I will be back when I get another code.
Old 08 May 2011, 07:14 pm
Welcome to the forum. Please do not use aftermarket sensors as our PT's do NOT like anything but OEM.
Old 09 May 2011, 05:37 pm
Well the code that came back today was P0522. I find that is my oil pressure sensor. Is it easy to change?
Old 09 May 2011, 05:48 pm
Some owners find it easy, some hard. I guess it depends on your lever of expertise.
Old 09 May 2011, 05:59 pm
Thanks CREWZIN maybe I can do it myself. At least I will look at it.
Starts and stops again? daggie Tech & Performance Forum 10 20 Oct 2012 08:33 am
Fan problem - it does not stops Rafaelhdezmex General Turbo Discussions 7 17 Jul 2009 06:08 pm
Bump stops R3dWhitNCrz Tech & Performance Forum 2 26 May 2005 07:59 pm
bump stops?? GTPT General Turbo Discussions 4 22 Apr 2003 01:49 pm
door stops latz-4657 Exterior Accessories Forum 4 06 Sep 2002 06:34 pm
