new engine in my 2001 pt
Old 09 May 2011, 12:45 pm
Default new engine in my 2001 pt
ok i have replaced engine in the pt 2001(185k) with a 2002 engine (60K) the care runs and it moves good no engine lights come on but the car runs ruff in idle it idles around 1200 rpm and then you touch the gas it revs up and down then it lopes or it idles around 1200 to 1250 up and down . if you put in to gear it stops but when out of gear it starts back up . is there anything i can do? i checked for leaks allready with wd40 nothing
Old 10 May 2011, 08:04 am
Default Re: new engine in my 2001 pt
You put in new plugs/wires?
Any codes?
Vacuum leaks?
2001 Engine swap mastifffreak Tech & Performance Forum 19 18 Feb 2014 10:35 am
2001 Replacing ERG-engine with NON-EGR srpmoinfo Tech & Performance Forum 3 15 Oct 2011 06:56 pm
2001 pt cruiser engine WJBREAUX Tech & Performance Forum 8 28 Sep 2010 04:05 pm
Can 2001 Engine be replaced with Newer Engine harleysforfun General PT Cruiser Discussions 1 07 Aug 2009 01:38 pm
BEST engine oil to use for PT Cruiser 2001 tvldeals Tech & Performance Forum 15 11 May 2005 03:29 pm
