SRS module location ? and full throttle surging
Old 10 May 2011, 02:30 pm
Default SRS module location ? and full throttle surging
Hello everyone. I am new here, I just recieved a 03 PT GT with 24k miles on here. I am an ex Master Dealer tech for Volvo, but it been years since I was wrenching. I have a faulty SRS module, and need to locate it, I would like to check the connections first, by no means will I be bent over by the dealer.
I had a the old shop i wrenched for scan it this morning and it has a permanent fault code that will not reset, the module keeps checking the air bags. Unfortunately, I didnt get the code. but I have faith in my old boss.
could someone tell me where the air bag module is located, i would rather not tear this car apart trying to find it ...
2nd issue, I get surging under full throttle 60-80 mph also feels like a slight missfire when parking in parking lots( more noticable in reverse). I have read about these cam sensors ect . Any other recommendations would be great . Thanks in advance...
Old 10 May 2011, 02:52 pm
RaineMan's Avatar
Default Re: SRS module location ? and full throttle surging
SRS... module? You mean the airbag itself or the computer unit that controls the airbags?
Old 10 May 2011, 04:38 pm
Try changing your plugs and wires (NOT OEM's). If you get a new sensor, use OEM as aftermarket are not liked by our PT's.
Old 10 May 2011, 04:54 pm
Here's the control from the Haynes manual.
As far as your surging, it is possible that the Camshaft sensor is going bad. Many owners have changed theirs. Usually there's a fault code to say that's bad, but again, the control usually fails altogether when the fault light shows up.
Its' located on the right side of the engine as you face it from the front.
How to Fix the Camshaft Sensor on a PT Cruiser | eHow.com
Old 11 May 2011, 05:07 pm
SRS module/computer/control unit, all the same thing.
Thanks alot for the info on location of the module....
Old 03 Jun 2014, 12:32 pm
randyincctx's Avatar
Lightbulb Re: SRS module location ? and full throttle surging
You could also check the connectors for the occupancy sensors(seat plugs),or the sensors located in the seatbelt retractors.
Aka:~KILLER~
Surging at Idle Scarlet2003 Tech & Performance Forum 9 18 May 2011 08:39 pm
2006 PT Cruiser sirius module location paradyne64 Sound and Security Forum 3 22 May 2010 02:15 pm
Surging Problems WikiFiend64 Tech & Performance Forum 4 16 May 2008 09:07 pm
04 Cruiser surging Ursa General PT Cruiser Discussions 6 09 Oct 2007 07:32 am
LOCATION OF AIRBAG CONTROL UNIT MODULE HYDROGENFUSION General PT Cruiser Discussions 0 18 Jun 2007 09:43 pm
