Multi Function Switch
Old 11 May 2011, 08:05 am
Default Multi Function Switch
The high beam lights would not work so I changed out the multi function switch. Now the turn signal and hazards do not work. I checked the fuse and change out the flasher any ideas?
thanks
Old 11 May 2011, 11:38 am
Default Re: Multi Function Switch
LOL, now I'm scared. Not making fun of your problem, just facing something similar. The low beams were not working this winter off and on, so we had to run around with the highs on, and that makes people happy. Since weather has turned warm it hasn't happed. This makes me really curious to what may happen when I get a new switch.
Old 11 May 2011, 11:39 am
Did you change the flasher from the old to the new? Don't ask how I know, but removing it twice taught me about my MF switch.
Old 11 May 2011, 12:22 pm
Yes put i put the old flasher on it did not work so i put a new flasher on it
Old 11 May 2011, 01:50 pm
Does it work now?
Old 11 May 2011, 07:17 pm
no the turn signal and the hazard do not work
Old 11 May 2011, 07:33 pm
You said you checked the fuse, did you check BOTH of them?
I think there's two: No#18 in the PDC under the hood and #15 in the interior fuse box.
Also check the #19 in the PDC. Even though it's listed at the "Power Outlets", the wiring diagram has it feeding power to the MFS and the combination Flasher unit.
Old 11 May 2011, 07:47 pm
I only checked the one in the interior. I did not know about the one under the hood. Thanks for the help I will let you know if that takes care of it.
I need this multi-function switch... anyone? Rowdy Classifieds: Want To Buy 12 07 Apr 2017 10:34 pm
how to install multi-function switch? Juicy General PT Cruiser Discussions 44 14 Apr 2014 01:13 pm
multi function switch problem neworder18 Tech & Performance Forum 4 10 Mar 2010 04:35 pm
Multi-function control switch RNCRUZR General PT Cruiser Discussions 5 05 Jun 2009 06:22 am
WTB - Multi-Function Switch ucantcme Classifieds: Want To Buy 11 13 Oct 2008 03:03 pm
