On and Off Dashboard Lights at startup
Old 11 May 2011, 05:05 pm
Default On and Off Dashboard Lights at startup
Not sure that's even a good title for this.
2006 PT Cruiser, approx 78k miles on it, basic model
Have a problem and have taken it to two different mechanics/shops and neither of them can figure out what's wrong they've both told me everything checks out fine. I'm about to take my cruiser on a 2300 mile roadtrip with me and my two pets.
Here's the problem:
When I startup the car (not everytime but approx 75-80% of the time) this happens: dashboard instruments go up and then back down to the bottom, all the lights and bells and whistles come on - for a very brief moment...then they go back to normal now rinse and repeat - does it again, sometimes three or four times.
I've stood next to the engine compartment when this happens (that seatbelt ding is loud) and I can't hear any changes to the sound of the engine when it does this. It doesn't sound like it's stopped, no funny sounds, everything "sounds" normal.
Once in a while it does this 'flash' (for lack of a better word) while I'm driving, but only for a brief moment. Car has twice been a little slow to start but nothing regular.
This has been going on for a few wks now. At first it was more intermittent, now occurs at again 75-80% of the time at startup, much more frequent in the heat of the day then first thing in the am when I go to work.
Alternator, electrical system, battery has all been checked out twice by two different mechanics and both said they couldn't find anything wrong and of course when I took it in, the car didn't do what I described above. Murphys Law #512.
Sorry to be such a long post.
Help please, any thoughts welcome. I do not need this, literally, breaking down in the desert with me and my pets.
Old 11 May 2011, 05:12 pm
Default Re: On and Off Dashboard Lights at startup
When you say the instruments go up and down ...do they all do it at once or each needle in each dial goes one at a time.
Do you know the trick of testing all the dials. Pushing in the odometer while turning n the key should start a series of tests of all the dials and odometer and lights. Sounds like a short somewhere in the testing circuit. Maybe taking the instrument cluster out, checking out any connections and putting it all back together or maybe the ignition switch has a short. Might want to try either of those.
Old 11 May 2011, 05:16 pm
Hi,
They do it all at once. Everything goes down, the lights all come on the dashboard, then they all go back up again. Repeatedly.
Beth
Old 11 May 2011, 06:34 pm
Would a marginal battery lead to this? Although, when the car is started, in theory, it is running off the alternator at that point.
alan
Old 11 May 2011, 08:30 pm
Go to a autl place and have them load test your battery!!!
Tags
dashboard, electrical, power, starting
Help! Flashing dashboard lights! Silvercat Tech & Performance Forum 2 31 Jan 2011 11:24 am
Why do my tail lights and dashboard lights only go on when I brake? bodykits Exterior Accessories Forum 1 16 May 2009 07:28 am
Dashboard Lights Out jlvia333 General PT Cruiser Discussions 4 16 Feb 2009 07:28 pm
tail/dashboard lights out chataries General PT Cruiser Discussions 1 30 Apr 2008 10:47 pm
Dashboard Lights seb97080 Interior Accessories Forum 0 17 Nov 2007 08:08 pm
